I have downloaded the following driver for my “MacBook” (graphic card / 02:00.0 VGA compatible controller: NVIDIA Corporation MCP89 [GeForce 320M] (rev a2))
Is this the right driver ?
I get the following failure-message (var/log/nvidia-installer-log):
Using: nvidia-installer ncurses user interface
-> License accepted.
-> Installing NVIDIA driver version 275.09.07.
WARNING: The path to the `modprobe` utility reported by
'/proc/sys/kernel/modprobe', `/sbin/modprobe`, differs from the path
determined by `nvidia-installer`, `/usr/sbin/modprobe`. Please verify
that `/sbin/modprobe` works correctly and correct the path in
'/proc/sys/kernel/modprobe' if it does not.
-> Performing CC sanity check with CC="cc".
-> Performing CC version check with CC="cc".
ERROR: The kernel header file
'/lib/modules/5.10.0-13-amd64/build/include/linux/version.h' does not
exist. The most likely reason for this is that the kernel source files
in '/lib/modules/5.10.0-13-amd64/build' have not been configured.
ERROR: Installation has failed. Please see the file
'/var/log/nvidia-installer.log' for details. You may find suggestions
on fixing installation problems in the README available on the Linux
driver download page at www.nvidia.com.
