Make with subdirectories
I have some C functions inside of a directory in the template folder. The problem is that I cannot get the “make” command to look inside of that directory for the code! the structure is as follows:
CUDASDK/projects/template:
—main.cu
—myFunctions/
------myFunction.c
What modification should I do to the Makefile in order for this to work?
Well, nobody seems to be interested. But I have found that the problem lies in rules definition within the common/common.mk file, for example:
$(OBJDIR)/%.c_o : $(SRCDIR)%.c $(C_DEPS)
$(VERBOSE)$(CC) $(CFLAGS) -o $@ -c $<
As we see, $(SRCDIR) forces the compiler to search ONLY in the source’s root directory (typically in the projects directory). I am not very experienced with Makefiles but the only workaround that I have found is to set up a new rule in the Makefile specifically for each source file inside of a subdirectory.
I hope somebody finds it useful.
