I’m retooling a program for CUDA but just discovered that I have no experience with makefiles which is less than I need. So my problem is that ‘make all’ does not recognize .cu files. I’ve set the default compiler to nvcc but it’s still not reading files appropriately (make[1]: *** No rule to make target file.o', needed by compile’. Stop.). That error happens when I change a file that I was going to leave as .C to .cu – it compiles fine before. So lets assume the file structure is src/extras, with file.o being in extras. There’s a makefile in src and another in extras, created by ./configure from Makefile.in templates. Here are what I think are the relevant parts of each:
To implicit rules in both files (with and without the percent signs)
and
SRC = $(OBJ:.o=.cu)
to macro definitions. All that I can change is that when I add the .cu implicit rule to both files (with or without percent signs) the error changes to ‘Makefile:36: *** missing separator. Stop.’ where line 36 is $(NVCC) $(NVCCFLAGS) -c $< -o in src/extras/Makefile.
I’m not sure where to go with this; any help would be greatly appreciated.
That’s the right approach. The trick is that the second line needs to start with a tab, no spaces.
That’s obviously only going to work if you rename all .c files to .cu. If you keep some .c files, you can take the opposite approach and derive $(OBJ) from $(SRC).
I fixed the spaces/tabs problem but that just returned my error to ‘*** No rule to make target file.o', needed by compile’.’
I’m not sure what you meant by reversing the derivation (I really am completely new to makefiles) so I tried to do it more explicitly (assuming two files in /src/extras, file.cu and regularfile.c):
nvcc fatal : No input files specified; use option --help for more information
make[1]: *** [regularfile.o] Error 255
make[1]: Leaving directory `/src/extras’
make: *** [compile] Error 2
This error recurs for various permutations of having and not having ‘-c’ for NVCC and CC in those definitions above. EDIT: I mention this because I sometimes also get an error from nvcc not recognizing ‘-c’, but just this second I’m having trouble reproducing it so maybe that’s no longer a problem.
Ah yes. That is because the extension for object files is .cu.o in some places and .o in others. Either name the file as file.cu.o in $(OBJ), or change the CUDA rule to
%.o: %.cu
$(NVCC) $(NVCCFLAGS) -c $< -o $@
(you may drop the “-o $@” in that case because it’s the default)
Sorry, my explanation was a bit short as I was in a hurry. Suppose your source files are a.c, b.c, c.cu, and d.cu. Then writing
