Hi, I’ve been messing round for the past day with setting frequencies and such. There are random moments when it will revert back to “ondemand” instead of “userspace” and I would refer you to this thread which covers a little bit of that and has a few neat scripts for reverting back to default if everything mucks up: https://devtalk.nvidia.com/default/topic/897506/jetson-tk1-cpu-scaling-governor-settings-not-sticking/?offset=5
The upshot of that is if you are not running from a ssh remotely there may be background processes forcing the cpu to change due to the file /etc/init.d/ondemand.
I have personally commented out line 51 of that file which is the culprit for setting the governor to something that is not “userspace”. I’m unsure how advisable this is but the board hasn’t blown up yet which I take as a good sign.
More specific to you if the cpuquiet/enable is set to 0 the userspace frequency setting doesn’t work (IDK why but I just tried and it doesn’t work).
To check whether it is enabled:
