I have meet a error when mass flash xavier by release_32.3.1.
First, I ran nvmassflashgen.sh:
|| Generate Massflash Image in the master host: ||
|| Requires the Jetson connected in RCM mode. ||
1 Jetson devices in RCM mode. USB: 2-4
| Step 1: Generate Command File
# L4T BSP Information:
# R32 , REVISION: 3.1
copying soft_fuses(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0042 ] Generating RCM messages
[ 0.0054 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0064 ] Header already present for /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0116 ]
[ 0.0137 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0149 ] Assuming zero filled SBK key
[ 0.0151 ]
[ 0.0163 ] tegrasign_v2 --key None --file /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0176 ] Assuming zero filled SBK key
[ 0.0183 ]
[ 0.0197 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0253 ]
[ 0.0265 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0278 ]
[ 0.0290 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0300 ] RCM 0 is saved as rcm_0.rcm
[ 0.0345 ] RCM 1 is saved as rcm_1.rcm
[ 0.0345 ] RCM 2 is saved as rcm_2.rcm
[ 0.0345 ] List of rcm files are saved in rcm_list.xml
[ 0.0345 ]
[ 0.0345 ] Signing RCM messages
[ 0.0356 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.0366 ] Assuming zero filled SBK key
[ 0.0376 ]
[ 0.0377 ] Copying signature to RCM mesages
[ 0.0393 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0413 ]
[ 0.0413 ] Boot Rom communication
[ 0.0424 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0436 ] RCM version 0X190001
[ 0.0452 ] Boot Rom communication completed
[ 1.0603 ]
[ 2.0645 ] tegrarcm_v2 --isapplet
[ 2.0675 ] Applet version 01.00.0000
[ 2.0830 ]
[ 2.0844 ] tegrarcm_v2 --ismb2
[ 2.1190 ]
[ 2.1217 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.1259 ]
[ 2.1277 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.1288 ] adding BCH for nvtboot_applet_t194.bin
[ 2.1322 ]
[ 2.1336 ] tegrasign_v2 --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.1347 ] Assuming zero filled SBK key
[ 2.1352 ]
[ 2.1372 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.1403 ]
[ 2.1418 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.1429 ] Applet version 01.00.0000
[ 2.1634 ] Sending mb2
[ 2.1637 ] [................................................] 100%
[ 2.1768 ]
[ 2.1786 ] tegrarcm_v2 --boot recovery
[ 2.1809 ] Applet version 01.00.0000
[ 2.2068 ]
[ 3.2110 ] tegrarcm_v2 --isapplet
[ 3.2316 ]
[ 3.2336 ] tegrarcm_v2 --ismb2
[ 3.2355 ] MB2 Applet version 01.00.0000
[ 3.2716 ]
[ 3.2731 ] tegrarcm_v2 --ismb2
[ 3.2748 ] MB2 Applet version 01.00.0000
[ 3.3115 ]
[ 3.3137 ] Retrieving EEPROM data
[ 3.3140 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3160 ] MB2 Applet version 01.00.0000
[ 3.3535 ] Saved platform info in /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/cvm.bin
[ 3.3882 ]
[ 3.3883 ] Rebooting to recovery mode
[ 3.3904 ] tegrarcm_v2 --ismb2
[ 3.3928 ] MB2 Applet version 01.00.0000
[ 3.4113 ]
[ 3.4114 ] Rebooting to recovery mode
[ 3.4135 ] tegrarcm_v2 --reboot recovery
[ 3.4157 ] MB2 Applet version 01.00.0000
[ 3.4586 ]
Board ID(2888) version(400) sku(0004) revision(G.0)
copying bctfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
populating kernel to rootfs... done.
version 1.0.0
[ 0.0040 ] Generating signature
[ 0.0050 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0061 ] Assuming zero filled SBK key
[ 0.0067 ]
[ 0.0068 ] header_magic: c05614
[ 0.0083 ] tegrahost_v2 --chip 0x19 --align 1_Image
[ 0.0094 ]
[ 0.0105 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_Image zerosbk
[ 0.0114 ] adding BCH for 1_Image
[ 1.0459 ]
[ 1.0473 ] tegrasign_v2 --key --list 1_Image_sigheader_list.xml --pubkeyhash pub_key.key
[ 1.0482 ] Assuming zero filled SBK key
[ 1.0945 ]
[ 1.0965 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_Image_sigheader.encrypt 1_Image_sigheader.hash zerosbk
[ 1.6280 ]
[ 1.6604 ] Signed file: /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/Image_sigheader.encrypt
Generate header for Image_sigheader.encrypt
Generate 16-byte-size-aligned base file for Image_sigheader.encrypt
Remove temporary file
done.
populating initrd to rootfs... done.
populating /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Making Boot image... done.
Existing sosfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/spe_t194.bin) reused.
Existing drameccfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/dram-ecc.bin) reused.
Existing badpagefile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/badpage.bin) reused.
Existing wb0boot(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
sed: 无法读取 /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/rootfs/etc/nv_boot_control.conf: 不是目录
version 1.0.0
[ 0.0039 ] Generating signature
[ 0.0049 ] tegrasign_v2 --key --getmode mode.txt
[ 0.0060 ] Assuming zero filled SBK key
[ 0.0064 ]
[ 0.0066 ] header_magic: d00dfeed
[ 0.0078 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0089 ]
[ 0.0101 ] tegrahost_v2 --chip 0x19 0 --magicid DATA --appendsigheader 1_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 0.0111 ] adding BCH for 1_tegra194-p2888-0001-p2822-0000.dtb
[ 0.0203 ]
[ 0.0218 ] tegrasign_v2 --key --list 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0228 ] Assuming zero filled SBK key
[ 0.0237 ]
[ 0.0260 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 0.0328 ]
[ 0.0335 ] Signed file: /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate header for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
Generate 16-byte-size-aligned base file for tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
Making system.img...
populating rootfs from /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/rootfs ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image...
---- Raw to Sparse Image Converter v1.0 ----------------------------
0: RAW: 4222976( 1031 blks) ==> 28:4222988
1: SKP: 57344( 14 blks) ==> 4223016:12
2: RAW: 4096( 1 blks) ==> 4223028:4108
3: SKP: 61440( 15 blks) ==> 4227136:12
4: RAW: 4096( 1 blks) ==> 4227148:4108
5: SKP: 33550336( 8191 blks) ==> 4231256:12
6: RAW: 24576( 6 blks) ==> 4231268:24588
7: SKP: 96292864( 23509 blks) ==> 4255856:12
8: RAW: 20480( 5 blks) ==> 4255868:20492
9: SKP: 4194304( 1024 blks) ==> 4276360:12
10: RAW: 28672( 7 blks) ==> 4276372:28684
11: SKP: 12288( 3 blks) ==> 4305056:12
12: RAW: 290816( 71 blks) ==> 4305068:290828
13: SKP: 28672( 7 blks) ==> 4595896:12
14: RAW: 8192( 2 blks) ==> 4595908:8204
15: SKP: 16384( 4 blks) ==> 4604112:12
16: RAW: 4096( 1 blks) ==> 4604124:4108
17: SKP: 299008( 73 blks) ==> 4608232:12
18: RAW: 385024( 94 blks) ==> 4608244:385036
19: SKP: 3100672( 757 blks) ==> 4993280:12
20: RAW: 15806464( 3859 blks) ==> 4993292:15806476
21: SKP: 53248( 13 blks) ==> 20799768:12
22: RAW: 147456( 36 blks) ==> 20799780:147468
23: SKP: 4096( 1 blks) ==> 20947248:12
24: RAW: 77824( 19 blks) ==> 20947260:77836
25: SKP: 8192( 2 blks) ==> 21025096:12
26: RAW: 331776( 81 blks) ==> 21025108:331788
27: SKP: 4096( 1 blks) ==> 21356896:12
28: RAW: 901120( 220 blks) ==> 21356908:901132
29: SKP: 8192( 2 blks) ==> 22258040:12
30: RAW: 143360( 35 blks) ==> 22258052:143372
31: SKP: 290816( 71 blks) ==> 22401424:12
32: RAW: 4186112( 1022 blks) ==> 22401436:4186124
33: SKP: 4096( 1 blks) ==> 26587560:12
34: RAW: 196608( 48 blks) ==> 26587572:196620
35: SKP: 278528( 68 blks) ==> 26784192:12
36: RAW: 278528( 68 blks) ==> 26784204:278540
37: SKP: 20480( 5 blks) ==> 27062744:12
38: RAW: 438272( 107 blks) ==> 27062756:438284
39: SKP: 4096( 1 blks) ==> 27501040:12
40: RAW: 4096( 1 blks) ==> 27501052:4108
41: SKP: 1339392( 327 blks) ==> 27505160:12
42: RAW: 49152( 12 blks) ==> 27505172:49164
43: SKP: 376832( 92 blks) ==> 27554336:12
44: RAW: 16384( 4 blks) ==> 27554348:16396
45: SKP: 4096( 1 blks) ==> 27570744:12
46: RAW: 24576( 6 blks) ==> 27570756:24588
47: SKP: 16384( 4 blks) ==> 27595344:12
48: RAW: 4096( 1 blks) ==> 27595356:4108
49: SKP: 4096( 1 blks) ==> 27599464:12
50: RAW: 4096( 1 blks) ==> 27599476:4108
51: SKP: 8192( 2 blks) ==> 27603584:12
52: RAW: 4096( 1 blks) ==> 27603596:4108
53: SKP: 8192( 2 blks) ==> 27607704:12
54: RAW: 4096( 1 blks) ==> 27607716:4108
55: SKP: 8192( 2 blks) ==> 27611824:12
56: RAW: 6508544( 1589 blks) ==> 27611836:6508556
57: SKP: 45056( 11 blks) ==> 34120392:12
58: RAW: 12288( 3 blks) ==> 34120404:12300
59: SKP: 8192( 2 blks) ==> 34132704:12
60: RAW: 1548288( 378 blks) ==> 34132716:1548300
61: SKP: 4096( 1 blks) ==> 35681016:12
62: RAW: 45056( 11 blks) ==> 35681028:45068
63: SKP: 8192( 2 blks) ==> 35726096:12
64: RAW: 315392( 77 blks) ==> 35726108:315404
65: SKP: 226492416( 55296 blks) ==> 36041512:12
66: RAW: 20480( 5 blks) ==> 36041524:20492
67: SKP: 268414976( 65531 blks) ==> 36062016:12
68: RAW: 20480( 5 blks) ==> 36062028:20492
69: SKP: 268414976( 65531 blks) ==> 36082520:12
70: RAW: 20480( 5 blks) ==> 36082532:20492
71: SKP: 268414976( 65531 blks) ==> 36103024:12
72: RAW: 20480( 5 blks) ==> 36103036:20492
73: SKP: 939503616( 229371 blks) ==> 36123528:12
74: RAW: 4096( 1 blks) ==> 36123540:4108
75: SKP: 1207955456( 294911 blks) ==> 36127648:12
76: RAW: 20480( 5 blks) ==> 36127660:20492
77: SKP: 268414976( 65531 blks) ==> 36148152:12
78: RAW: 20480( 5 blks) ==> 36148164:20492
79: SKP: 671068160( 163835 blks) ==> 36168656:12
80: RAW: 4096( 1 blks) ==> 36168668:4108
81: SKP: 2147479552( 524287 blks) ==> 36172776:12
82: RAW: 4096( 1 blks) ==> 36172788:4108
83: SKP: 134213632( 32767 blks) ==> 36176896:12
84: RAW: 20480( 5 blks) ==> 36176908:20492
85: SKP: 2013245440( 491515 blks) ==> 36197400:12
86: RAW: 8192( 2 blks) ==> 36197412:8204
87: SKP: 57344( 14 blks) ==> 36205616:12
88: RAW: 4096( 1 blks) ==> 36205628:4108
89: SKP: 61440( 15 blks) ==> 36209736:12
90: RAW: 4096( 1 blks) ==> 36209748:4108
91: SKP: 33550336( 8191 blks) ==> 36213856:12
92: RAW: 8192( 2 blks) ==> 36213868:8204
93: SKP: 100524032( 24542 blks) ==> 36222072:12
94: RAW: 6131712( 1497 blks) ==> 36222084:6131724
95: SKP: 2007134208( 490023 blks) ==> 42353808:12
96: RAW: 4096( 1 blks) ==> 42353820:4108
97: SKP: 134213632( 32767 blks) ==> 42357928:12
98: RAW: 20480( 5 blks) ==> 42357940:20492
99: SKP: 2013245440( 491515 blks) ==> 42378432:12
100: RAW: 4096( 1 blks) ==> 42378444:4108
101: SKP: 2147479552( 524287 blks) ==> 42382552:12
102: RAW: 8192( 2 blks) ==> 42382564:8204
103: SKP: 134209536( 32766 blks) ==> 42390768:12
104: RAW: 77824( 19 blks) ==> 42390780:77836
105: SKP: 1610534912( 393197 blks) ==> 42468616:12
106: RAW: 20480( 5 blks) ==> 42468628:20492
107: SKP: 402632704( 98299 blks) ==> 42489120:12
108: RAW: 4096( 1 blks) ==> 42489132:4108
109: SKP: 2147479552( 524287 blks) ==> 42493240:12
110: RAW: 4096( 1 blks) ==> 42493252:4108
111: SKP: 2147479552( 524287 blks) ==> 42497360:12
112: RAW: 4096( 1 blks) ==> 42497372:4108
113: SKP: 2147479552( 524287 blks) ==> 42501480:12
114: RAW: 4096( 1 blks) ==> 42501492:4108
115: SKP: 2147479552( 524287 blks) ==> 42505600:12
116: RAW: 4096( 1 blks) ==> 42505612:4108
117: SKP: 2147479552( 524287 blks) ==> 42509720:12
118: RAW: 4096( 1 blks) ==> 42509732:4108
119: SKP: 2147479552( 524287 blks) ==> 42513840:12
-- Total: ---------------------------------------------------
120 CHUNK 30064771072(7340032 blks) ==> 42513852(10379 blks)
done.
system.img built successfully.
Existing tbcfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd "flash; reboot" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"
saving flash command in /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/flash_win.bat
*** no-flash flag enabled. Exiting now... ***
| Step 2: Sign Binaries
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --odmdata 0x9190000 --applet mb1_t194_prod.bin --cmd " sign" --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --cfg flash.xml --chip 0x19 --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb" --keep --skipuid
version 1.0.0
[ 0.0492 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0509 ] Assuming zero filled SBK key
[ 0.0512 ]
[ 0.0609 ] Generating RCM messages
[ 0.0760 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[ 0.0772 ] Header already present for mb1_t194_prod.bin
[ 0.0817 ]
[ 0.0830 ] tegrasign_v2 --key None --getmode mode.txt
[ 0.0843 ] Assuming zero filled SBK key
[ 0.0845 ]
[ 0.0858 ] tegrasign_v2 --key None --file mb1_t194_prod_sigheader.bin --offset 2960 --length 1136 --pubkeyhash pub_key.key
[ 0.0867 ] Assuming zero filled SBK key
[ 0.0874 ]
[ 0.0885 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[ 0.0937 ]
[ 0.1138 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[ 0.1250 ]
[ 0.1328 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[ 0.1341 ] RCM 0 is saved as rcm_0.rcm
[ 0.1385 ] RCM 1 is saved as rcm_1.rcm
[ 0.1385 ] RCM 2 is saved as rcm_2.rcm
[ 0.1385 ] List of rcm files are saved in rcm_list.xml
[ 0.1385 ]
[ 0.1385 ] Signing RCM messages
[ 0.1396 ] tegrasign_v2 --key None --list rcm_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 0.1407 ] Assuming zero filled SBK key
[ 0.1418 ]
[ 0.1418 ] Copying signature to RCM mesages
[ 0.1429 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.1446 ]
[ 0.1447 ] Parsing partition layout
[ 0.1728 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.1750 ]
[ 0.1751 ] Creating list of images to be signed
[ 0.1763 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
[ 0.1775 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.1785 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.1914 ] MB1: Nvheader already present is mb1_t194_prod.bin
[ 0.2003 ] Header already present for mb1_t194_prod_sigheader.bin
[ 0.2015 ] adding BCH for spe_t194.bin
[ 0.2059 ] adding BCH for spe_t194.bin
[ 0.2088 ] adding BCH for nvtboot_t194.bin
[ 0.2118 ] adding BCH for nvtboot_t194.bin
[ 0.2171 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2224 ] Header already present for preboot_c10_prod_cr.bin
[ 0.2228 ] Header already present for mce_c10_prod_cr.bin
[ 0.2234 ] Header already present for mce_c10_prod_cr.bin
[ 0.2294 ] adding BCH for mts_c10_prod_cr.bin
[ 0.2341 ] adding BCH for mts_c10_prod_cr.bin
[ 0.3357 ] adding BCH for cboot_t194.bin
[ 0.4366 ] adding BCH for cboot_t194.bin
[ 0.4500 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.4642 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 0.4725 ] adding BCH for tos-trusty_t194.img
[ 0.4814 ] adding BCH for tos-trusty_t194.img
[ 0.4914 ] adding BCH for eks.img
[ 0.5010 ] adding BCH for eks.img
[ 0.5015 ] adding BCH for bpmp_t194.bin
[ 0.5023 ] adding BCH for bpmp_t194.bin
[ 0.5285 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.5760 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 0.5913 ] adding BCH for camera-rtcpu-rce.img
[ 0.6065 ] adding BCH for camera-rtcpu-rce.img
[ 0.6147 ] adding BCH for adsp-fw.bin
[ 0.6234 ] adding BCH for adsp-fw.bin
[ 0.6268 ] Header already present for warmboot_t194_prod.bin
[ 0.6305 ] Header already present for warmboot_t194_prod.bin
[ 0.6316 ] adding BCH for boot.img
[ 0.6611 ] adding BCH for boot.img
[ 1.8502 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.0466 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 3.5177 ]
[ 3.5177 ] Filling MB1 storage info
[ 3.5177 ] Generating br-bct
[ 3.5188 ] Performing cfg overlay
[ 3.5188 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[ 3.5198 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg
[ 3.8554 ]
[ 3.8555 ] Updating dev and MSS params in BR BCT
[ 3.8555 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 3.9243 ]
[ 3.9244 ] Updating bl info
[ 3.9254 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[ 3.9280 ]
[ 3.9280 ] Generating signatures
[ 3.9292 ] tegrasign_v2 --key None --list images_list.xml --pubkeyhash pub_key.key
[ 3.9302 ] Assuming zero filled SBK key
[ 4.1938 ]
[ 4.1938 ] Generating br-bct
[ 4.1950 ] Performing cfg overlay
[ 4.1950 ] ['/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg']
[ 4.1950 ] Updating dev and MSS params in BR BCT
[ 4.1951 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[ 4.5916 ]
[ 4.5917 ] Updating bl info
[ 4.5950 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 4.6021 ]
[ 4.6021 ] Updating smd info
[ 4.6038 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[ 4.6058 ]
[ 4.6058 ] Updating Odmdata
[ 4.6074 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[ 4.6095 ]
[ 4.6096 ] Get Signed section of bct
[ 4.6110 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[ 4.6128 ]
[ 4.6141 ] tegrasign_v2 --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[ 4.6150 ] Assuming zero filled SBK key
[ 4.6154 ]
[ 4.6155 ] Updating BCT with signature
[ 4.6165 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[ 4.6179 ]
[ 4.6179 ] Generating coldboot mb1-bct
[ 4.6194 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.6204 ] MB1-BCT version: 0x1
[ 4.6208 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.6213 ] Added Platform Config 0 data with size :- 2976
[ 4.6394 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.6399 ] Added Platform Config 1 data with size :- 19640
[ 4.6795 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.6801 ] Added Platform Config 2 data with size :- 24
[ 4.6941 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.6950 ] Added Platform Config 4 data with size :- 348
[ 4.6956 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.6965 ] Added Platform Config 3 data with size :- 92
[ 4.6970 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.6979 ] Added Platform Config 5 data with size :- 56
[ 4.6984 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.6991 ] Added Platform Config 7 data with size :- 392
[ 4.6996 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.7002 ] Added Platform Config 8 data with size :- 12
[ 4.7024 ]
[ 4.7024 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.7024 ] Added Platform Config 9 data with size :- 32
[ 4.7024 ]
[ 4.7024 ] Updating mb1-bct with firmware information
[ 4.7038 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.7051 ] MB1-BCT version: 0x1
[ 4.7059 ]
[ 4.7059 ] Updating mb1-bct with storage information
[ 4.7071 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.7084 ] MB1-BCT version: 0x1
[ 4.7089 ]
[ 4.7101 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[ 4.7114 ]
[ 4.7124 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[ 4.7134 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[ 4.7145 ]
[ 4.7157 ] tegrasign_v2 --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.7166 ] Assuming zero filled SBK key
[ 4.7170 ]
[ 4.7185 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[ 4.7203 ]
[ 4.7204 ] Generating recovery mb1-bct
[ 4.7217 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.7227 ] MB1-BCT version: 0x1
[ 4.7231 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[ 4.7237 ] Added Platform Config 0 data with size :- 2976
[ 4.7258 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[ 4.7262 ] Added Platform Config 1 data with size :- 19640
[ 4.7443 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[ 4.7449 ] Added Platform Config 2 data with size :- 24
[ 4.7453 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[ 4.7459 ] Added Platform Config 4 data with size :- 348
[ 4.7463 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[ 4.7469 ] Added Platform Config 3 data with size :- 92
[ 4.7472 ]
[ 4.7473 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[ 4.7473 ] Added Platform Config 5 data with size :- 56
[ 4.7473 ]
[ 4.7473 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[ 4.7473 ] Added Platform Config 7 data with size :- 392
[ 4.7473 ]
[ 4.7473 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[ 4.7473 ] Added Platform Config 8 data with size :- 12
[ 4.7473 ]
[ 4.7473 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[ 4.7473 ] Added Platform Config 9 data with size :- 32
[ 4.7473 ]
[ 4.7473 ] Updating mb1-bct with firmware information
[ 4.7483 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.7492 ] MB1-BCT version: 0x1
[ 4.7497 ]
[ 4.7497 ] Updating mb1-bct with storage information
[ 4.7507 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[ 4.7516 ] MB1-BCT version: 0x1
[ 4.7520 ]
[ 4.7531 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[ 4.7541 ]
[ 4.7552 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --appendsigheader mb1_bct_MB1.bct zerosbk
[ 4.7562 ] adding BCH for mb1_bct_MB1.bct
[ 4.7577 ]
[ 4.7590 ] tegrasign_v2 --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.7598 ] Assuming zero filled SBK key
[ 4.7601 ]
[ 4.7616 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[ 4.7631 ]
[ 4.7632 ] Generating coldboot mem-bct
[ 4.7641 ] tegrabct_v2 --chip 0x19 0 --sdram /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg --membct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_1.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_2.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_3.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_4.bct
[ 4.7650 ] Packing sdram param for instance[0]
[ 4.8181 ] Packing sdram param for instance[1]
[ 4.8184 ] Packing sdram param for instance[2]
[ 4.8187 ] Packing sdram param for instance[3]
[ 4.8190 ] Packing sdram param for instance[4]
[ 4.8190 ] Packing sdram param for instance[5]
[ 4.8190 ] Packing sdram param for instance[6]
[ 4.8190 ] Packing sdram param for instance[7]
[ 4.8190 ] Packing sdram param for instance[8]
[ 4.8190 ] Packing sdram param for instance[9]
[ 4.8190 ] Packing sdram param for instance[10]
[ 4.8190 ] Packing sdram param for instance[11]
[ 4.8190 ] Packing sdram param for instance[12]
[ 4.8190 ] Packing sdram param for instance[13]
[ 4.8190 ] Packing sdram param for instance[14]
[ 4.8190 ] Packing sdram param for instance[15]
[ 4.8190 ]
[ 4.8190 ] Getting sector size from pt
[ 4.8200 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 4.8211 ]
[ 4.8212 ] BlockSize read from layout is 200
[ 4.8222 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_1.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_2.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_3.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_4.bct
[ 4.8232 ] adding BCH for /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_1.bct
[ 4.8268 ]
[ 4.8278 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[ 4.8288 ]
[ 4.8300 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_coldboot.bct zerosbk
[ 4.8312 ] Header already present for mem_coldboot.bct
[ 4.8317 ]
[ 4.8332 ] tegrasign_v2 --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.8343 ] Assuming zero filled SBK key
[ 4.8348 ]
[ 4.8362 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[ 4.8376 ]
[ 4.8377 ] Generating recovery mem-bct
[ 4.8388 ] tegrabct_v2 --chip 0x19 0 --sdram /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1.cfg --membct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_1.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_2.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_3.bct /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811/tmpZCbT2E1_4.bct
[ 4.8398 ] Packing sdram param for instance[0]
[ 4.8926 ] Packing sdram param for instance[1]
[ 4.8931 ] Packing sdram param for instance[2]
[ 4.8931 ] Packing sdram param for instance[3]
[ 4.8931 ] Packing sdram param for instance[4]
[ 4.8931 ] Packing sdram param for instance[5]
[ 4.8931 ] Packing sdram param for instance[6]
[ 4.8931 ] Packing sdram param for instance[7]
[ 4.8932 ] Packing sdram param for instance[8]
[ 4.8932 ] Packing sdram param for instance[9]
[ 4.8932 ] Packing sdram param for instance[10]
[ 4.8932 ] Packing sdram param for instance[11]
[ 4.8932 ] Packing sdram param for instance[12]
[ 4.8932 ] Packing sdram param for instance[13]
[ 4.8932 ] Packing sdram param for instance[14]
[ 4.8932 ] Packing sdram param for instance[15]
[ 4.8932 ]
[ 4.8945 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[ 4.8956 ]
[ 4.8967 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --appendsigheader mem_rcm.bct zerosbk
[ 4.8976 ] adding BCH for mem_rcm.bct
[ 4.8997 ]
[ 4.9010 ] tegrasign_v2 --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[ 4.9020 ] Assuming zero filled SBK key
[ 4.9029 ]
[ 4.9048 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[ 4.9071 ]
[ 4.9072 ] Copying signatures
[ 4.9082 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.0915 ]
[ 7.0949 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 7.2322 ]
[ 7.2374 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_t194.bin
[ 7.2389 ]
[ 7.2404 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --appendsigheader nvtboot_recovery_t194.bin zerosbk
[ 7.2418 ] adding BCH for nvtboot_recovery_t194.bin
[ 7.2489 ]
[ 7.2510 ] tegrasign_v2 --key None --list nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.2526 ] Assuming zero filled SBK key
[ 7.2535 ]
[ 7.2558 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_t194_sigheader.bin.encrypt nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[ 7.2598 ]
[ 7.2611 ] tegrahost_v2 --chip 0x19 --align preboot_c10_prod_cr.bin
[ 7.2626 ]
[ 7.2640 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader preboot_c10_prod_cr.bin zerosbk
[ 7.2651 ] Header already present for preboot_c10_prod_cr.bin
[ 7.2660 ]
[ 7.2673 ] tegrasign_v2 --key None --list preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.2682 ] Assuming zero filled SBK key
[ 7.2687 ]
[ 7.2702 ] tegrahost_v2 --chip 0x19 0 --updatesigheader preboot_c10_prod_cr_sigheader.bin.encrypt preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.2719 ]
[ 7.2729 ] tegrahost_v2 --chip 0x19 --align mce_c10_prod_cr.bin
[ 7.2740 ]
[ 7.2749 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader mce_c10_prod_cr.bin zerosbk
[ 7.2758 ] Header already present for mce_c10_prod_cr.bin
[ 7.2784 ]
[ 7.2796 ] tegrasign_v2 --key None --list mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.2805 ] Assuming zero filled SBK key
[ 7.2812 ]
[ 7.2828 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mce_c10_prod_cr_sigheader.bin.encrypt mce_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.2872 ]
[ 7.2883 ] tegrahost_v2 --chip 0x19 --align mts_c10_prod_cr.bin
[ 7.2891 ]
[ 7.2903 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader mts_c10_prod_cr.bin zerosbk
[ 7.2915 ] adding BCH for mts_c10_prod_cr.bin
[ 7.3956 ]
[ 7.3969 ] tegrasign_v2 --key None --list mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.3981 ] Assuming zero filled SBK key
[ 7.4064 ]
[ 7.4081 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mts_c10_prod_cr_sigheader.bin.encrypt mts_c10_prod_cr_sigheader.bin.hash zerosbk
[ 7.4619 ]
[ 7.4630 ] tegrahost_v2 --chip 0x19 --align bpmp_t194.bin
[ 7.4640 ]
[ 7.4650 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --appendsigheader bpmp_t194.bin zerosbk
[ 7.4660 ] adding BCH for bpmp_t194.bin
[ 7.4927 ]
[ 7.4940 ] tegrasign_v2 --key None --list bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.4949 ] Assuming zero filled SBK key
[ 7.4965 ]
[ 7.4982 ] tegrahost_v2 --chip 0x19 0 --updatesigheader bpmp_t194_sigheader.bin.encrypt bpmp_t194_sigheader.bin.hash zerosbk
[ 7.5200 ]
[ 7.5213 ] tegrahost_v2 --chip 0x19 --align tegra194-a02-bpmp-p2888-a04.dtb
[ 7.5225 ]
[ 7.5237 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --appendsigheader tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[ 7.5247 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[ 7.5401 ]
[ 7.5422 ] tegrasign_v2 --key None --list tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 7.5432 ] Assuming zero filled SBK key
[ 7.5444 ]
[ 7.5459 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[ 7.5555 ]
[ 7.5567 ] tegrahost_v2 --chip 0x19 --align spe_t194.bin
[ 7.5579 ]
[ 7.5591 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --appendsigheader spe_t194.bin zerosbk
[ 7.5600 ] adding BCH for spe_t194.bin
[ 7.5634 ]
[ 7.5647 ] tegrasign_v2 --key None --list spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.5657 ] Assuming zero filled SBK key
[ 7.5663 ]
[ 7.5677 ] tegrahost_v2 --chip 0x19 0 --updatesigheader spe_t194_sigheader.bin.encrypt spe_t194_sigheader.bin.hash zerosbk
[ 7.5703 ]
[ 7.5714 ] tegrahost_v2 --chip 0x19 --align tos-trusty_t194.img
[ 7.5725 ]
[ 7.5736 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --appendsigheader tos-trusty_t194.img zerosbk
[ 7.5747 ] adding BCH for tos-trusty_t194.img
[ 7.5852 ]
[ 7.5868 ] tegrasign_v2 --key None --list tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 7.5878 ] Assuming zero filled SBK key
[ 7.5887 ]
[ 7.5901 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tos-trusty_t194_sigheader.img.encrypt tos-trusty_t194_sigheader.img.hash zerosbk
[ 7.5962 ]
[ 7.5974 ] tegrahost_v2 --chip 0x19 --align eks.img
[ 7.5989 ]
[ 7.6003 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --appendsigheader eks.img zerosbk
[ 7.6014 ] adding BCH for eks.img
[ 7.6017 ]
[ 7.6029 ] tegrasign_v2 --key None --list eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 7.6039 ] Assuming zero filled SBK key
[ 7.6044 ]
[ 7.6059 ] tegrahost_v2 --chip 0x19 0 --updatesigheader eks_sigheader.img.encrypt eks_sigheader.img.hash zerosbk
[ 7.6072 ]
[ 7.6084 ] tegrahost_v2 --chip 0x19 --align tegra194-p2888-0001-p2822-0000.dtb
[ 7.6096 ]
[ 7.6107 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --appendsigheader tegra194-p2888-0001-p2822-0000.dtb zerosbk
[ 7.6117 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[ 7.6225 ]
[ 7.6239 ] tegrasign_v2 --key None --list tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 7.6248 ] Assuming zero filled SBK key
[ 7.6256 ]
[ 7.6272 ] tegrahost_v2 --chip 0x19 0 --updatesigheader tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[ 7.6329 ]
[ 7.6341 ] tegrahost_v2 --chip 0x19 --align nvtboot_recovery_cpu_t194.bin
[ 7.6352 ]
[ 7.6361 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --appendsigheader nvtboot_recovery_cpu_t194.bin zerosbk
[ 7.6371 ] adding BCH for nvtboot_recovery_cpu_t194.bin
[ 7.6464 ]
[ 7.6480 ] tegrasign_v2 --key None --list nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 7.6489 ] Assuming zero filled SBK key
[ 7.6497 ]
[ 7.6510 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_recovery_cpu_t194_sigheader.bin.encrypt nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[ 7.6562 ]
[ 7.6563 ] Copying signed file in /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/signed
[ 8.3516 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
[ 9.6197 ]
Keep temporary directory /home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/7811
| Step 3: Generate Mass-flash scripts
| Step 4: Generate Mass-flash image tarball
copying nvmflash.sh ... succeeded.
copying nvaflash.sh ... succeeded.
number of images in blob are 11
blobsize is 5985208
Added binary nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 256592
Added binary nvtboot_recovery_t194_sigheader.bin.encrypt of size 129936
Added binary preboot_c10_prod_cr_sigheader.bin.encrypt of size 23968
Added binary mce_c10_prod_cr_sigheader.bin.encrypt of size 144144
Added binary mts_c10_prod_cr_sigheader.bin.encrypt of size 3372048
Added binary bpmp_t194_sigheader.bin.encrypt of size 853856
Added binary tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 500672
Added binary spe_t194_sigheader.bin.encrypt of size 94960
Added binary tos-trusty_t194_sigheader.img.encrypt of size 324608
Added binary eks_sigheader.img.encrypt of size 5136
Added binary tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 279104
mfi_jetson-xavier/
mfi_jetson-xavier/preboot_c10_prod_cr.bin
mfi_jetson-xavier/tegra194-p2888-0001-p2822-0000_sigheader.dtb
mfi_jetson-xavier/tos-trusty_t194.img
mfi_jetson-xavier/bpmp_t194_sigheader.bin_list.xml
mfi_jetson-xavier/mb1_cold_boot_bct_MB1.bct
mfi_jetson-xavier/tegra194-a02-bpmp-p2888-a04_sigheader.dtb
mfi_jetson-xavier/br_bct_BR.bct
mfi_jetson-xavier/LICENSE.cboot_t194
mfi_jetson-xavier/tegra194-p2888-0001-p2822-0000_sigheader.dtb_list_signed.xml
mfi_jetson-xavier/warmboot_t194_prod.bin
mfi_jetson-xavier/tegraflash_internal.pyc
mfi_jetson-xavier/clone.img
mfi_jetson-xavier/rcm_2_encrypt.rcm
mfi_jetson-xavier/gpt_primary_1_3.bin
mfi_jetson-xavier/tmpZCbT2E1.cfg
mfi_jetson-xavier/LICENSE.u-boot
mfi_jetson-xavier/temp_misc_cold_boot.cfg
mfi_jetson-xavier/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
mfi_jetson-xavier/LICENSE.spe_t194.bin
mfi_jetson-xavier/adsp-fw.bin
mfi_jetson-xavier/mem_rcm_sigheader.bct_list_signed.xml
mfi_jetson-xavier/mce_mts_d15_prod_cr.bin
mfi_jetson-xavier/tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list_signed.xml
mfi_jetson-xavier/xusb_sil_rel_fw
mfi_jetson-xavier/flash_win.bat
mfi_jetson-xavier/nvtboot_recovery.bin
mfi_jetson-xavier/rcm_1_encrypt.rcm
mfi_jetson-xavier/nvtboot_recovery_t194_sigheader.bin_list_signed.xml
mfi_jetson-xavier/mfi.log
mfi_jetson-xavier/flash.xml.bin
mfi_jetson-xavier/preboot_d15_prod_cr.bin
mfi_jetson-xavier/gpt_secondary_0_3.bin
mfi_jetson-xavier/tegradevflash_v2
mfi_jetson-xavier/mce_c10_prod_cr_sigheader.bin
mfi_jetson-xavier/initrd
mfi_jetson-xavier/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
mfi_jetson-xavier/mts_c10_prod_cr_sigheader.bin_list.xml
mfi_jetson-xavier/spe_t194.bin
mfi_jetson-xavier/bpmp.bin
mfi_jetson-xavier/l4t_initrd.img
mfi_jetson-xavier/chkbdinfo
mfi_jetson-xavier/eks_sigheader.img_list_signed.xml
mfi_jetson-xavier/LICENSE.mkbctpart
mfi_jetson-xavier/mb1_cold_boot_bct_MB1_sigheader.bct_list_signed.xml
mfi_jetson-xavier/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
mfi_jetson-xavier/smd_info.cfg
mfi_jetson-xavier/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
mfi_jetson-xavier/tegra194-mb1-bct-memcfg-p2888.cfg
mfi_jetson-xavier/tos_t194.img
mfi_jetson-xavier/nvtboot_applet_t194.bin
mfi_jetson-xavier/nvtboot_recovery_cpu_t194_sigheader.bin.encrypt
mfi_jetson-xavier/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
mfi_jetson-xavier/tegrarcm_v2
mfi_jetson-xavier/boot_sigheader.img
mfi_jetson-xavier/tegrabct_v2
mfi_jetson-xavier/rcm_0_encrypt.rcm
mfi_jetson-xavier/tos-trusty_t194_sigheader.img_list.xml
mfi_jetson-xavier/cvm.bin
mfi_jetson-xavier/tos.img
mfi_jetson-xavier/bct_list.xml
mfi_jetson-xavier/tegra186-bpmp-quill-p3310-1000-a00-00.dtb
mfi_jetson-xavier/mbr_1_3.bin
mfi_jetson-xavier/LICENSE.mkgpt
mfi_jetson-xavier/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
mfi_jetson-xavier/spe_t194_sigheader.bin_list_signed.xml
mfi_jetson-xavier/cboot_t194_sigheader.bin
mfi_jetson-xavier/cboot.bin
mfi_jetson-xavier/mem_rcm_sigheader.bct.encrypt
mfi_jetson-xavier/camera-rtcpu-rce.img
mfi_jetson-xavier/mb1_prod.bin
mfi_jetson-xavier/mkbctpart
mfi_jetson-xavier/preboot_c10_prod_cr_sigheader.bin_list_signed.xml
mfi_jetson-xavier/mb1_bct_MB1_sigheader.bct_list.xml
mfi_jetson-xavier/spe.bin
mfi_jetson-xavier/tmpZCbT2E1_3.bct
mfi_jetson-xavier/LICENSE.adsp
mfi_jetson-xavier/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
mfi_jetson-xavier/tos-mon-only.img
mfi_jetson-xavier/spe_t194_sigheader.bin.encrypt
mfi_jetson-xavier/slot_metadata.bin
mfi_jetson-xavier/tegra194-mb1-soft-fuses-l4t.cfg
mfi_jetson-xavier/adsp-fw_sigheader.bin.encrypt
mfi_jetson-xavier/tos-trusty_t194_sigheader.img_list_signed.xml
mfi_jetson-xavier/mce_c10_prod_cr_sigheader.bin_list_signed.xml
mfi_jetson-xavier/camera-rtcpu-rce_sigheader.img
mfi_jetson-xavier/preboot_c10_prod_cr_sigheader.bin.encrypt
mfi_jetson-xavier/mb1_t194_prod_sigheader.bin.encrypt
mfi_jetson-xavier/blob.bin
mfi_jetson-xavier/nvtboot_recovery_t194_sigheader.bin.encrypt
mfi_jetson-xavier/tegra194-memcfg-sw-override.cfg
mfi_jetson-xavier/nvidia-l4t-bootloader_32.3.1-20191209230245_arm64.deb
mfi_jetson-xavier/cboot_t194.bin
mfi_jetson-xavier/BUP_generator.py
mfi_jetson-xavier/tegrahost_v2
mfi_jetson-xavier/br_bct_BR.bct.encrypt
mfi_jetson-xavier/rcm_1.rcm
mfi_jetson-xavier/LICENSE.nv_smd_generator
mfi_jetson-xavier/images_list.xml
mfi_jetson-xavier/spe_t194_sigheader.bin_list.xml
mfi_jetson-xavier/mem_coldboot_sigheader.bct_list.xml
mfi_jetson-xavier/LICENSE.bpmp
mfi_jetson-xavier/tegra194-mb1-bct-misc-flash.cfg
mfi_jetson-xavier/tegraparser_v2
mfi_jetson-xavier/badpage.bin
mfi_jetson-xavier/bmp.blob
mfi_jetson-xavier/nvtboot_recovery_cpu_t194.bin
mfi_jetson-xavier/nv_boot_control.conf
mfi_jetson-xavier/mts_c10_prod_cr_sigheader.bin.encrypt
mfi_jetson-xavier/nvtboot_t194_sigheader.bin.encrypt
mfi_jetson-xavier/mce_c10_prod_cr_sigheader.bin.encrypt
mfi_jetson-xavier/mem_rcm_sigheader.bct_list.xml
mfi_jetson-xavier/LICENSE.chkbdinfo
mfi_jetson-xavier/NVIDIA_Trademark_License_Addendum_SW.pdf
mfi_jetson-xavier/bct_list_signed.xml
mfi_jetson-xavier/LICENSE.camera-rtcpu
mfi_jetson-xavier/LICENSE.spe.bin
mfi_jetson-xavier/camera-rtcpu-sce.img
mfi_jetson-xavier/mce_c10_prod_cr.bin
mfi_jetson-xavier/mem_coldboot.bct
mfi_jetson-xavier/images_list_signed.xml
mfi_jetson-xavier/LICENSE.tos-mon-only_t194.img.arm-trusted-firmware
mfi_jetson-xavier/mksparse
mfi_jetson-xavier/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
mfi_jetson-xavier/cbo.dts
mfi_jetson-xavier/tegra194-mb1-bct-scr-cbb-mini.cfg
mfi_jetson-xavier/sfuse.bin
mfi_jetson-xavier/nvtboot_cpu_t194.bin
mfi_jetson-xavier/LICENSE.tos-trusty.img.trusty
mfi_jetson-xavier/eks_sigheader.img_list.xml
mfi_jetson-xavier/LICENSE.bpmp_t194
mfi_jetson-xavier/LICENSE.mksparse
mfi_jetson-xavier/tegrasign_v2
mfi_jetson-xavier/mb1_bct_MB1.bct
mfi_jetson-xavier/tos-trusty_t194_sigheader.img.encrypt
mfi_jetson-xavier/nvtboot_t194.bin
mfi_jetson-xavier/rcm_list.xml
mfi_jetson-xavier/tegra194-a02-bpmp-p2888-a04.dtb
mfi_jetson-xavier/mkbootimg
mfi_jetson-xavier/mem_rcm.bct
mfi_jetson-xavier/tmpZCbT2E1_2.bct
mfi_jetson-xavier/preboot_c10_prod_cr_sigheader.bin_list.xml
mfi_jetson-xavier/flash.xml_BR.bct
mfi_jetson-xavier/blob.xml
mfi_jetson-xavier/tos-trusty.img
mfi_jetson-xavier/warmboot_t194_prod_sigheader.bin
mfi_jetson-xavier/gpt_secondary_1_3.bin
mfi_jetson-xavier/nvtboot_recovery_cpu.bin
mfi_jetson-xavier/bpmp_t194.bin
mfi_jetson-xavier/tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
mfi_jetson-xavier/tegra194-p2888-0001-p2822-0000.dtb
mfi_jetson-xavier/nv_smd_generator
mfi_jetson-xavier/nvmflash.sh
mfi_jetson-xavier/mb1_t194_prod_sigheader_encrypt.bin
mfi_jetson-xavier/mb1_recovery_prod.bin
mfi_jetson-xavier/nvtboot_cpu.bin
mfi_jetson-xavier/tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
mfi_jetson-xavier/extlinux.conf
mfi_jetson-xavier/tmpZCbT2E1_1.bct
mfi_jetson-xavier/tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml
mfi_jetson-xavier/mem_coldboot_sigheader.bct_list_signed.xml
mfi_jetson-xavier/mce_c10_prod_cr_sigheader.bin_list.xml
mfi_jetson-xavier/mb1_cold_boot_bct_MB1_sigheader.bct_list.xml
mfi_jetson-xavier/nvtboot_recovery_cpu_t194_sigheader.bin_list_signed.xml
mfi_jetson-xavier/bpmp_t194_sigheader.bin.encrypt
mfi_jetson-xavier/camera-rtcpu-rce_sigheader.img.encrypt
mfi_jetson-xavier/nvtboot_recovery_t194.bin
mfi_jetson-xavier/rcm_2.rcm
mfi_jetson-xavier/flash.idx
mfi_jetson-xavier/cboot_t194_sigheader.bin.encrypt
mfi_jetson-xavier/tmpZCbT2E1_4.bct
mfi_jetson-xavier/eks_sigheader.img.encrypt
mfi_jetson-xavier/mb1_bct_MB1_sigheader.bct.encrypt
mfi_jetson-xavier/nvaflash.sh
mfi_jetson-xavier/boot_sigheader.img.encrypt
mfi_jetson-xavier/mts_c10_prod_cr.bin
mfi_jetson-xavier/LICENSE.mkbootimg
mfi_jetson-xavier/tegra194-mb1-bct-misc-l4t.cfg
mfi_jetson-xavier/mb1_bct_MB1_sigheader.bct_list_signed.xml
mfi_jetson-xavier/mem_coldboot_sigheader.bct.encrypt
mfi_jetson-xavier/bpmp_t194_sigheader.bin_list_signed.xml
mfi_jetson-xavier/rcm_list_signed.xml
mfi_jetson-xavier/tos-mon-only_t194.img
mfi_jetson-xavier/dram-ecc.bin
mfi_jetson-xavier/tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml
mfi_jetson-xavier/nvtboot_recovery_t194_sigheader.bin_list.xml
mfi_jetson-xavier/sector_info.bin
mfi_jetson-xavier/warmboot_t194_prod_sigheader.bin.encrypt
mfi_jetson-xavier/LICENSE.tos-trusty_t194.img.arm-trusted-firmware
mfi_jetson-xavier/system.img
mfi_jetson-xavier/LICENSE.tos-mon-only.img.arm-trusted-firmware
mfi_jetson-xavier/mts_c10_prod_cr_sigheader.bin_list_signed.xml
mfi_jetson-xavier/tegra194-br-bct-sdmmc.cfg
mfi_jetson-xavier/tegra19x-mb1-bct-device-sdmmc.cfg
mfi_jetson-xavier/LICENSE.tos-trusty_t194.img.trusty
mfi_jetson-xavier/boot.img
mfi_jetson-xavier/LICENSE.mce_c10_prod_cr
mfi_jetson-xavier/rcm_0.rcm
mfi_jetson-xavier/tegraflash.py
mfi_jetson-xavier/eks.img
mfi_jetson-xavier/nvtboot_recovery_cpu_t194_sigheader.bin_list.xml
mfi_jetson-xavier/mkgpt
mfi_jetson-xavier/LICENSE.tos-trusty.img.arm-trusted-firmware
mfi_jetson-xavier/mb1_t194_prod.bin
mfi_jetson-xavier/sw_memcfg_overlay.pl
mfi_jetson-xavier/temp_misc.cfg
*** Mass Flashing tarball mfi_jetson-xavier.tbz2 is ready.
1. Download mfi_jetson-xavier.tbz2 to each flashing hosts.
2. Untar mfi_jetson-xavier.tbz2. ( tar xvjf mfi_jetson-xavier.tbz2 )
3. cd mfi_jetson-xavier
4. Connect Jetson boards(jetson-xavier only) and put them in RCM mode.
5. ./nvmflash.sh
Then I entered mfi_jetson-xavier folder in the same host, and ran nvmflash.sh to flash two xavier machines(in RCM mode):
Start flashing device: 2-4, PID: 8657
Start flashing device: 2-2, PID: 8659
Flash complete (WITH FAILURES)
But both failed, the mfilogs shows:
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegrarcm_v2 --instance 2-2 --chip 0x19 0 --rcm rcm_list_signed.xml
BR_CID: 0x880219116420f1420c00000006018280
*** Boot Rom communication succeeded.
*** Checking applet
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegrarcm_v2 --instance 2-2 --isapplet
*** Checking applet succeeded.
*** Sending BCTs
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegrarcm_v2 --instance 2-2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
Sending bct_bootrom
Sending bct_mb1
Sending bct_mem
*** Sending BCTs succeeded.
*** Sending bootloader and pre-requisite binaries
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegrarcm_v2 --instance 2-2 --download blob blob.bin
Sending blob
[........ ] 017%
[................. ] 035%
[.......................... ] 052%
[................................... ] 070%
[........................................... ] 087%
*** Sending bootloader and pre-requisite binaries succeeded.
*** Booting Recovery
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegrarcm_v2 --instance 2-2 --boot recovery
*** Booting Recovery succeeded.
*** Checking applet
*** Checking CPU bootloader
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegradevflash_v2 --instance 2-2 --iscpubl
Bootloader version 01.00.0000
*** Checking CPU bootloader succeeded.
*** Flashing the device
/home/xiaochuan/work/t19k510/nvidia_jetson_32.3.1/flashtool/Linux_for_Tegra/bootloader/mfi_jetson-xavier/tegradevflash_v2 --instance 2-2 --pt flash.xml.bin --create
Erasing sdmmc_boot: 3 ......... [Done]
Writing partition secondary_gpt with gpt_secondary_0_3.bin
000000000d0d0001: o initialize partition table from GPT.
*** Error: Flashing the device failed.```
