I am getting an error when using the --massflash option with initrd flash on BSP 32.7.1 to flash a Xavier with NVMe. The flash host is Ubuntu 22.04.3 LTS.
The process works for one board at a time but fails when two or more are connected. These are the steps to reproduce:
Prepare massflash
# ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --network usb0 --massflash 5 --external-device nvme0n1 -c flash_l4t_nvme_rootfs_ab2samsung232Gcustom.xml -S 32GiB --showlogs jetson-xavier-nx-devkit-emmc external
Attach two devices in recovery mode
**# lsusb**
Bus 001 Device 020: ID 0955:7e19 NVIDIA Corp. APX
Bus 001 Device 022: ID 0955:7e19 NVIDIA Corp. APX
Run massflash
**# ROOTFS_AB=1 ./tools/kernel_flash/l4t_initrd_flash.sh --flash-only --network usb0 --massflash 5 --external-device nvme0n1 -c flash_l4t_nvme_rootfs_ab2samsung232Gcustom.xml -S 32GiB --showlogs jetson-xavier-nx-devkit-emmc external**
/tmp/tmpcassette/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-2.1 --device-instance 0 --flash-only --external-device nvme0n1 -c "flash_l4t_nvme_rootfs_ab2samsung232Gcustom.xml" -S 32GiB jetson-xavier-nx-devkit-emmc external
Start flashing device: 1-2.1, rcm instance: 0, PID: 128643
Log will be saved to Linux_for_Tegra/initrdlog/flash_1-2.1_0_20231005-112952.log
/tmp/tmpcassette/tools/kernel_flash/l4t_initrd_flash_internal.sh --network usb0 --usb-instance 1-2.2 --device-instance 1 --flash-only --external-device nvme0n1 -c "flash_l4t_nvme_rootfs_ab2samsung232Gcustom.xml" -S 32GiB jetson-xavier-nx-devkit-emmc external
Start flashing device: 1-2.2, rcm instance: 1, PID: 128646
Log will be saved to Linux_for_Tegra/initrdlog/flash_1-2.2_1_20231005-112952.log
**Flash complete (WITH FAILURES)**
Log output
**# tail -F initrdlog/*.log**
==> initrdlog/flash_1-2.1_0_20231005-112952.log <==
==> initrdlog/flash_1-2.2_1_20231005-112952.log <==
exportfs: duplicated export entries:
exportfs: fc00:1:1::/48:/tmp/tmpcassette/rootfs
Cleaning up...
Cleaning up...
It seems to double write to /etc/exports but I can’t fix it.
How do I get past that to flash several Xaviers at one time?
Thanks,
Mickey
