Massflash disk encryption with jetpack5.1.3 jetson orin nano
I tried disk encryption massflash with generic-passphrase facing error.
ERROR: camera-ip/isp5/isp5.c:1980 [isp5_pm_init] “ERROR: Failed to turn isp power on”
BUG: core/init/init.c:85 [init_all] “*** FIRMWARE INIT FAILED AT LEVEL 95 ***”
massflash_error.log (24.5 KB)
Hi mrcloud,
Are you using the devkit or custom board for Orin Nano?
Jetson UEFI firmware (version 202210.4-Unknown built on 2024-05-14T02:24:20+00:00)
Have you customized and updated the UEFI binary?
Please share the detailed steps how you generate package for Massflash and also the logs for further check.
Hi Kevin,
I already know how to solve it, need connect device to run the command.
Else the chip_sku and ramcode will be different if using the default.
is there any way can generate without plug the device in recovery mode?
as i not able to find a way define chip_sku and ramcode.
Yes, it may read the board sku/id/fab from the device in recovery during generating the package.
You can specify them(BOARDID, FAB, BOARDSKU and BOARDREV) in the command when you are generating the package.
Please refer to Workflow 7: Initrd Massflash in <Linux_for_Tegra>/tools/kernel_flashREADME_initrd_flash.txt for details.
