Hello!
I’m trying to do a matrix inverse via CUDA fortran.
If I were not in CUDA, I would use getrf for the LU decomposition, followed by getri.
Can I do this via cusolver, please? I see the subroutine for the equivalent of getrf, but not getri.
Or would it be better to use cublas, please?
Thanks,
Erin
cublas only has batched versions of getrf/getrs. If you only need to do one matrix inversion, I would suggest using cusolver getrf followed by getrs on the identity matrix. I’m not sure if we had a getri function it would run any faster than getrs on the identity.
It works like a charm!
Thank you so much for your help.
Would you like to see the code, or are you good, please?
Thanks,
Erin
