Hi, I’ll apologize in advance for the awkward question but, AFAIK, if we multiply A matrix with B matrix and get C, then the following dimensions hold:
A X B = C
[NxM] [MxL] [NxL]
So, how come when I run the matrixMul on a Tesla C2050 I get the following output on the console:
Using Matrix Sizes: A(640 x 960), B(640 x 640), C(640 x 960)
, which translates to
A X B = C
[640x960] [640x640] [640x960]
Even if we accessed A transposed the output matrix C would be [960x640], unless the result is transposed.
“Equivalently” if its B x A, then the dimensions are correct. Which one holds?
Right. Thank you for your link. Tell me, can I overload the matrix multiplication so that it supports finit field arithmetics? Matrix-matrix memory instructions remains the same, only the arithmetic instructions change. Is it possible?
