Matrix multiplication
I m new on Cuda and I m trying to implement my first matrix multiplication but it doesn’t work. Can someone help me to find the error?
[codebox]
#define TILE_WIDTH 2
#define N 5
#define M 3
#define P 2
int main{
dim3 threadsPerBlock(TILE_WIDTH,TILE_WIDTH);
dim3 numBlocks(N /threadsPerBlock.x, P /threadsPerBlock.y);
simpleMultiply<<<numBlocks, threadsPerBlock>>>(d_A, d_B, d_C, N, M, P); // it should perform C=A*B where A[N][M], B[M][P], C[N][P]
global void simpleMultiply(float* A, float* B, float* C, int NN, int MM , int PP) {
int bx = blockIdx.x; int by = blockIdx.y;
int tx = threadIdx.x; int ty = threadIdx.y;
//we are processing element C[row][col];
// TILE_WIDTH is the block dimension BLOCK = [TILE_WIDTH][TILE_WIDTH]
int row = by * TILE_WIDTH + ty;
int col = bx * TILE_WIDTH + tx;
if ((row<N) && (col<M)){
// Matricies in Cuda are arranged by columns --> A[i][j] = A[i + N*j] where dim A[N x M]
float sum = 0.0f;
    for (int i = 0; i < MM; i++) {
	sum += A[row + NN*i] * B[i + MM*col];  // sum += A[row][i] * B[i][col]
C[row + col*NN] = sum;
}[/codebox]
Try this:
[codebox]
#define N 5
#define M 3
#define P 2
int main{
dim3 threadsPerBlock(TILE_WIDTH, TILE_WIDTH);
dim3 numBlocks((N + TILE_WIDTH - 1) / TILE_WIDTH, (P + TILE_WIDTH - 1) / TILE_WIDTH);
if ((row<NN) && (col<PP)){
float sum = 0.0f;
}[/codebox]
Try this:
[codebox]
#define N 5
#define M 3
#define P 2
int main{
float sum = 0.0f;
}[/codebox]
Thanks, Tera but it still doesn’t work…any others suggestions?
Ok, I may have missed more mistakes. They might be easier to find if you tell us what goes wrong.
EDIT: And show the code to copy to and from the device too.
The full code is
[codebox]include <stdio.h>
include <stdlib.h>
include <cutil_inline.h>
include <matGiulio.h>
include <cublas.h>
extern global void simpleMultiply(float* A, float* B, float* C,int N, int M ,int P) ;
define TILE_WIDTH 2
define N 5
define M 3
define P 2
constant float* d_A;
constant float* d_B;
float* d_C;
int main(){
float A[N][M] = {1,2,3,4,5,6,6,8,9,10,11,12,13,14,15};
float B[M][P] = {1,2,3,4,5,6};
float* h_A;
float* h_B;
float* h_C;
h_A = (float *) calloc( N*M,sizeof(float) );
h_B = (float *) calloc( M*P,sizeof(float) );
h_C = (float *) calloc( N*P,sizeof(float) );
h_A = &A[0][0];
h_B = &B[0][0];
cudaMalloc((void**)&d_A, N*M*sizeof(float));
cudaMalloc((void**)&d_B, M*P*sizeof(float));
cudaMalloc((void**)&d_C, N*P*sizeof(float));
cudaMemcpy(d_A, h_A , N*M*sizeof(float),cudaMemcpyHostToDevice);
cudaMemcpy(d_B, h_B , M*P*sizeof(float),cudaMemcpyHostToDevice);
cudaMemcpy(d_C, h_C , N*P*sizeof(float),cudaMemcpyHostToDevice);
printCublasDevMat(d_C,N,P);
prodMat(h_A, h_B, h_C, N, M, P);
printMat(h_C, N, P);
printf( " \n Press ENTER to continue..." );
while (getchar() != '\n');
if (system( "clear" )) system( "cls" );
return 0;
float sum = 0.0f;
	sum += A[row + MM*i] * B[i + PP*col];  // sum += A[row][i] * B[i][col]
}[/codebox]
and the result is
27 36
0 0
0 49
66 0
0 0
but the right result is
22 28
49 64
75 98
103 136
130 172
I am sure that all other function are fine…so the problem is the GPU kernel.
I found one error on matrix indices :(, but it still doesn’t work…the code is the same but with
[codebox]global void simpleMultiply(float* A, float* B, float* C, int NN, int MM , int PP) {
float sum = 0.0f;
int i;
    for (i = 0; i < MM; i++) {
	sum += A[row*MM + i] * B[i*PP + col];  // sum += A[row][i] * B[i][col]
	C[row*PP + col] = sum;
[/codebox]
the result now is
and the result is
22 28
0 0
0 0
0 0
0 0
…the first row is correct!
