I’m learning cuda with the “NVIDIA CUDA programming guide”.
I implemented the “Matrix Multipliation without Shared Memory” (pg 20-22) but it doesn’t work very well.
Here’s my code :
#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include <cuda_runtime.h>
#include <time.h>
// Matrices are stored in row-major order:
// M(row, col) = *(M.elements + row * M.width + col)
typedef struct {
int width;
int height;
float *elements;
} Matrix;
// Thread block size
#define BLOCK_SIZE 16
// Forward declaration of the matrix multiplication kernel
__global__ void MatMulKernel(const Matrix, const Matrix, Matrix);
// Matrix multiplication - Host code
// Matrix dimensions are assumed to be multiples of BLOCK_SIZE
void matrixMulGPU(const Matrix A, const Matrix B, Matrix C)
// Load A and B to device memory
Matrix d_A;
d_A.width = A.width; d_A.height = A.height;
size_t size = A.width * A.height * sizeof(float);
cudaMalloc((void**)&d_A.elements, size);
cudaMemcpy(d_A.elements, A.elements, size,
cudaMemcpyHostToDevice);
Matrix d_B;
d_B.width = B.width; d_B.height = B.height;
size = B.width * B.height * sizeof(float);
cudaMalloc((void**)&d_B.elements, size);
cudaMemcpy(d_B.elements, B.elements, size,
// Allocate C in device memory
Matrix d_C;
d_C.width = C.width; d_C.height = C.height;
size = C.width * C.height * sizeof(float);
cudaMalloc((void**)&d_C.elements, size);
// Invoke kernel
dim3 dimBlock(BLOCK_SIZE, BLOCK_SIZE);
dim3 dimGrid(B.width / dimBlock.x + 1, A.height / dimBlock.y + 1);
MatMulKernel<<<dimGrid, dimBlock>>>(d_A, d_B, d_C);
// Read C from device memory
cudaMemcpy(C.elements, d_C.elements, size,
cudaMemcpyDeviceToHost);
// Free device memory
cudaFree(d_A.elements);
cudaFree(d_B.elements);
cudaFree(d_C.elements);
cudaThreadExit();
// Matrix multiplication kernel called by MatMul()
__global__ void MatMulKernel(Matrix A, Matrix B, Matrix C)
// Each thread computes one element of C
// by accumulating results into Cvalue
float Cvalue = 0;
int row = blockIdx.y * blockDim.y + threadIdx.y;
int col = blockIdx.x * blockDim.x + threadIdx.x;
for (int e = 0; e < A.width; ++e) {
Cvalue += A.elements[row * A.width + e]
* B.elements[e * B.width + col];
__syncthreads();
C.elements[row * C.width + col] = Cvalue;
float floatRand(float MaxVal) {
return ( (float)rand() / (float)RAND_MAX ) * MaxVal;
void timedate() {
time_t temps_act;
time(&temps_act);
printf("%s\n", ctime(&temps_act));
void matrixMulCPU(Matrix M, Matrix N, Matrix P) {
int i, j, k;
for(i=0; i<M.height; i++) {
for(j=0; j<N.width; j++) {
for(k=0; k<M.width; k++) {
P.elements[i*N.width + j] += M.elements[i*M.width + k]
* N.elements[k*N.width + j];
int main() {
int size = 10;
int i, j;
int print = true;
Matrix A;
Matrix B;
Matrix C;
Matrix D;
A.width = size;
A.height = size;
A.elements = (float*) malloc(A.width*A.height*sizeof(float));
B.width = size;
B.height = size;
B.elements = (float*) malloc(B.width*B.height*sizeof(float));
C.width = size;
C.height = size;
C.elements = (float*) malloc(C.width*C.height*sizeof(float));
D.width = size;
D.height = size;
D.elements = (float*) malloc(D.width*D.height*sizeof(float));
printf("matrix generation\n");
srand ( time(NULL) );
for(i=0; i<size*size; i++) {
A.elements[i] = 2; //floatRand(2);
B.elements[i] = 2; //floatRand(2);
// A.elements[i] = 3;
// B.elements[i] = 3;
C.elements[i] = 0;
D.elements[i] = 0;
if(print) {
printf("A =\n");
for(i=0; i<A.height; i++) {
for(j=0; j<A.width; j++) {
printf("%f ",A.elements[i*size + j]);
printf("\n");
printf("\n\n");
printf("B =\n");
for(i=0; i<B.height; i++) {
for(j=0; j<B.width; j++) {
printf("%f ",B.elements[i*size + j]);
printf("\n");
timedate();
printf("GPU matrix multiplication\n");
matrixMulGPU(A, B, C);
timedate();
timedate();
printf("CPU matrix multiplication\n");
matrixMulCPU(A, B, D);
timedate();
//print result
if(print) {
printf("C =\n");
for(i=0; i<C.height; i++) {
for(j=0; j<C.width; j++) {
printf("%f ",C.elements[i*size + j]);
printf("\n");
printf("\n\n");
printf("D =\n");
for(i=0; i<D.height; i++) {
for(j=0; j<D.width; j++) {
printf("%f ",D.elements[i*size + j]);
printf("\n");
and here’s the result I have with my Geforce 9650M GT :
matrix generation
A =
2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000 2.000000
B =
Mon Nov 23 20:02:55 2009
C =
40.000000 40.000000 40.000000 40.000000 40.000000 40.000000 40.000000 40.000000 40.000000 40.000000
nan -20769186196199271228741710417756160.000000 32.000000 nan nan nan 40.000000 40.000000 40.000000 40.000000
D =
Some strange values or NaN appear on the gpu. I should missed something… help! :huh:
Thanks in advance External Image
ps: I’m running ubuntu 9.10 with forceware 190.42 (from https://launchpad.net/~nvidia-vdpau/+archive/ppa)
