Description
Hi
I am tring to update my code from TRT 7.1 to TRT 7.2.
I found add_matrix_multiply
give right answer on TensorRT 7.1.3.4,but fail on TensorRT 7.2.1.6 with error log:
[TensorRT] INTERNAL ERROR: Assertion failed: cublasStatus == CUBLAS_STATUS_SUCCESS
../rtSafe/cublas/cublasLtWrapper.cpp:279
Environment
TensorRT Version: 7.1.3.4/ 7.2.1.6
GPU Type: 2070 Super
Nvidia Driver Version: 450.80.02
CUDA Version: 10.2
CUDNN Version: 8.0.4
Operating System + Version: ubuntu18.04
Python Version (if applicable): 3.7
TensorFlow Version (if applicable):
PyTorch Version (if applicable): 1.7.0
Baremetal or Container (if container which image + tag):
Steps To Reproduce
import tensorrt as trt
import torch
import numpy as np
def main():
print("create trt model")
log_level = trt.Logger.ERROR
logger = trt.Logger(log_level)
builder = trt.Builder(logger)
## build network
EXPLICIT_BATCH = 1 << (int)(
trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
network = builder.create_network(EXPLICIT_BATCH)
input1_name = 'input1'
input2_name = 'input2'
output_name = 'output'
input1_trt = network.add_input(name=input1_name,
shape=[1, 4100, 25],
dtype=trt.float32)
input2_trt = network.add_input(name=input2_name,
shape=[1, 25, 4100],
dtype=trt.float32)
# matmul
matmul_trt = network.add_matrix_multiply(
input1_trt, trt.MatrixOperation.NONE, input2_trt,
trt.MatrixOperation.NONE).get_output(0)
output = matmul_trt
output.name = output_name
network.mark_output(output)
## builder config
max_workspace_size = 1 << 30
fp16_mode = False
builder.max_workspace_size = max_workspace_size
builder.fp16_mode = fp16_mode
config = builder.create_builder_config()
config.max_workspace_size = max_workspace_size
profile = builder.create_optimization_profile()
# set shape
input1_shape = (1, 4100, 25)
profile.set_shape(input1_name, input1_shape, input1_shape, input1_shape)
input2_shape = (1, 25, 4100)
profile.set_shape(input2_name, input2_shape, input2_shape, input2_shape)
config.add_optimization_profile(profile)
if fp16_mode:
config.set_flag(trt.BuilderFlag.FP16)
# build engine
engine = builder.build_engine(network, config)
context = engine.create_execution_context()
print("inference")
input1_torch = torch.rand(1, 4100, 25).cuda().contiguous()
input2_torch = torch.rand(1, 25, 4100).cuda().contiguous()
bindings = [None] * 3
# set input
idx = engine.get_binding_index(input1_name)
context.set_binding_shape(idx, tuple(input1_torch.shape))
bindings[idx] = input1_torch.data_ptr()
idx = engine.get_binding_index(input2_name)
context.set_binding_shape(idx, tuple(input2_torch.shape))
bindings[idx] = input2_torch.data_ptr()
# set output
idx = engine.get_binding_index(output_name)
shape = tuple(context.get_binding_shape(idx))
output_torch = torch.empty(shape, dtype=torch.float32).cuda()
bindings[idx] = output_torch.data_ptr()
context.execute_async_v2(bindings, torch.cuda.current_stream().cuda_stream)
print(output_torch.shape)
print(output_torch.view(-1)[:10])
if __name__ == "__main__":
main()
On TensorRT 7.1.3.4 the log:
create trt model
inference
torch.Size([1, 4100, 4100])
tensor([5.5353, 4.6237, 5.2224, 7.7332, 6.3585, 4.7470, 5.5884, 4.8122, 6.1835,
5.2994], device='cuda:0')
On TensorRT 7.2.1.6 the log:
create trt model
inference
Aborting...
[TensorRT] ERROR: FAILED_EXECUTION: std::exception
tensor([0., 0., 0., 0., 0., 0., 0., 0., 0., 0.], device='cuda:0')
Did I miss some config on 7.2.1.6? How do I fix this?
