As I understand there issue is due to my tensorrt version 8.2.1.8 is linked to cublas version 10.2.3. but it is installed v. 10.2.2.
As I work in container I start from this image:
FROM nvidia/cuda:10.2-cudnn8-devel-ubuntu18.04
were cuda 10.2 is installed.
As I understand I should update version of libcublas but it is usually installed with cuda.
Is there any chance to fix it?
I have read the installation guide provided here:
And I choose to install from tar package.
Another suggestion to use ngc containers
But the container with tensorrt 8.2.1. 22.01-py3 is linked to cuda 11.6 but not cuda 10.2 and I can not switch the version of cuda.
Environment
TensorRT Version: 8.2.1.8 GPU Type: RTX 2080 TI Nvidia Driver Version: 470.103.01 CUDA Version: 10.2 CUDNN Version: 8.2 Operating System + Version: Ubuntu 18.04 Python Version (if applicable): TensorFlow Version (if applicable): PyTorch Version (if applicable): Baremetal or Container (if container which image + tag):
As the support matrix doc indicates, you need to update the cuBlas version. Or you may need to use a lower version of the TensorRT to match your environment.
Thanks, I understand that I need to upgrade cublas, but it’s not clear how to do this in docker. I can not find smth like apt install clibcublas or so on. As I understand cublas is installed along with cuda. What is the easiest way to upgrade ?
After installing cuda 10.2 patch 1 and patch 2, I had cublas 10.2.3. I think only patch 2 contains cublas 10.2.3, patch 1 includes only cublas 10.2.2.214.
After patch 2 libcublas.so.10.2.3.254 and other .so files are installed.
But so far I haven’t found any official cuda image containing 10.2 with patch 1 and patch 2, and I don’t know if you can install a runfile inside docker.
This is not pretty, and I think nvidia should instead update their images to contain the patches for a proper solution. Shouldn’t be too much of an effort on their part. Please? :)
