I followed the video tutorial, Error occurs after execute “train_ssd.py”
please help
Hi @jusltop, it would seem like an image from your dataset is missing or corrupted. You can either try re-downloading the dataset, or add some debug print-outs to the code to determine which image it is that is failing to load. For example, you can add a print statement below this line of code:
print(str(image_file))
Then the last filename before the exception is thrown is the one that is causing the error.
