Megatron Bridge uses endless vram on GB10
Hey everyone, I have a 2x GB10 setup with 200gbe infiniband. I have been trying to utilize Megatron-Bridge (nvcr.io/nvidia/nemo:26.04.00) to leverage fp8 training and ideally better performance via transformer engine, however it looks completely unusable right now compared to HF Transformers.
Specifically, I am OOMing with extremely low batch sizes and context lengths seemingly for no reason. I have been trying to train Qwen 3.5 9B with 64 dim peft, however it looks like I am utilizing way too much vram. I thought this was raw DDP related, however it seems to be problematic when sharding my model using tensor paralleism=2. For example the config below already OOMs:
        torchrun \
          --nnodes="${PET_NNODES}" \
          --nproc_per_node=1 \
          --node_rank="${PET_NODE_RANK}" \
          --master_addr="${PET_MASTER_ADDR}" \
          --master_port="${PET_MASTER_PORT}" \
          scripts/training/run_recipe.py \
          --recipe "${MEGBRIDGE_RECIPE}" \
          --dataset vlm-preloaded \
          --seq_length 2048 \
          --step_func qwen3_vl_step \
          dataset.hf_processor_path=/workspace/megbridge/models/qwen3.5-9B-megatron/iter_0000000/tokenizer \
          dataset.train_data_path=/workspace/megbridge/data/sft-smoke/training.jsonl \
          dataset.valid_data_path=null \
          dataset.test_data_path=null \
          dataset.pack_sequences_in_batch=False \
          dataset.num_workers=16 \
          dataset.pin_memory=true \
          train.train_iters=1000 \
          train.global_batch_size=8 \
          train.micro_batch_size=4 \
          validation.eval_iters=0 \
          validation.eval_interval=1000000 \
          mixed_precision=bf16_mixed \
          checkpoint.save=/workspace/megbridge/checkpoints/finetune_smoke \
          checkpoint.load=null \
          checkpoint.pretrained_checkpoint=/workspace/megbridge/models/qwen3.5-9B-megatron-tp2 \
          checkpoint.save_interval=1000 \
          model.seq_length=2048 \
          model.tensor_model_parallel_size=2 \
          model.pipeline_model_parallel_size=1 \
          model.context_parallel_size=1 \
          model.recompute_granularity=full \
          model.recompute_method=uniform \
          model.recompute_num_layers=1 \
          model.sequence_parallel=true \
          model.freeze_vision_model=true \
          model.freeze_vision_projection=true \
          optimizer.lr=0.0001 \
          optimizer.min_lr=0.00001 \
          optimizer.weight_decay=0.01 \
          optimizer.optimizer=adam \
          optimizer.use_precision_aware_optimizer=true \
          optimizer.main_grads_dtype=bf16 \
          optimizer.main_params_dtype=fp32 \
          optimizer.exp_avg_dtype=bf16 \
          optimizer.exp_avg_sq_dtype=bf16 \
          optimizer.store_param_remainders=true \
          scheduler.lr_warmup_iters=10 \
          scheduler.lr_decay_style=cosine \
          logger.log_interval=10 \
          logger.log_params_norm=false \
          logger.log_throughput=true \
          logger.log_progress=true \
          logger.wandb_project=test_megatron \
          logger.wandb_exp_name=qwen3.5-9b-smoke \
          logger.wandb_save_dir=/workspace/megbridge/runs/finetune_smoke/wandb \
          rng.seed=1234 \
          model.attention_backend=flash_attn \
          '+peft={dim:64,alpha:64,dropout:0.0,dropout_position:pre,target_modules:[linear_qkv,linear_proj,in_proj,out_proj,linear_fc1,linear_fc2]}'
My current vram utilization with this exact script which supposedly aggressively reduces vram (e.g. via layerwise rematerialization) still reaches 110gb+ and sometimes OOMs. From what I understand, adam keeps fp32 master weights, which is fine by me, but this doesn’t explain the other lost vram.
According to raw calculations, with this exact setup:
  • Global batch size 8
  • full layerwise remat
  • fp32 master weights
  • context 2048
  • Flash attention
It should be using ~47-50GB, not 220gb+.
Am I missing any critical setting, or is there some sort of bug with megatron-bridge for GB10? In this current state, megatron bridge seems completely unusable compared to raw hf transformers or unsloth.
Looks like it’s balooning and allocating a ton of vram compared to what it’s actually using:
Looks like i found the bugs:
  • Dataloaders were using ~14GB memory
  • Changing from qwen3_vl_step to vlm_step halved my memory. Looks like that one doesn’t allocate memory correctly in tp=2
