Mellanox SN2410 with Cumulius Linux
Hi to all, I wanted to ask you a question, is it possible to install cumulus linux on a mellanox SN2410 switch? Thanks in advance.
SN2410 is not supported. See below for the list of switches for this platform.
https://nvdam.widen.net/s/llbvwv5rfx/br-sn2000-series
You need an active support and create an issue asking about migration. They will check the specs and ask for approval internally. If you are lucky you receive the steps to migrate and while still under support.
hi,SN4280-X , Support installation Onyx?
