Im using SRIOV using Openstack(version: Antelope) which is deployed using kolla-ansible deployment (single node setup).
Ethernet card details:
root@poc-dev-3:/home/user# lspci -nnv -s a2:00.0
a2:00.0 Ethernet controller [0200]: Mellanox Technologies MT2892 Family [ConnectX-6 Dx] [15b3:101d]
Subsystem: Mellanox Technologies MT2892 Family [ConnectX-6 Dx] [15b3:0040]
Physical Slot: 5
Flags: bus master, fast devsel, latency 0, IRQ 18, NUMA node 2, IOMMU group 161
Memory at e0000000 (64-bit, prefetchable) [size=32M]
Capabilities: [60] Express Endpoint, MSI 00
Capabilities: [48] Vital Product Data
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Capabilities: [c0] Vendor Specific Information: Len=18 <?>
Capabilities: [40] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [180] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1c0] Secondary PCI Express
Capabilities: [320] Lane Margining at the Receiver <?>
Capabilities: [370] Physical Layer 16.0 GT/s <?>
Capabilities: [420] Data Link Feature <?>
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
OS Version: Ubuntu 22.04.5 LTS
Grub changes:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX="vfio_iommu_type1.allow_unsafe_interrupts=1 iommu=pt intel_iommu=on"
SDN used: OVN(enabled with DHCP)
Number of VF’s created using the following command:
echo '7' > /sys/class/net/ens3np0/device/sriov_numvfs
root@poc-dev-3:/home/user# cat /sys/class/net/ens3np0/device/sriov_totalvfs
8
Other Info:
- Enabled SRIOV & VT-d in the BIOS configuration
- Enabled iommu=pt intel_iommu=on on the grub changes and rebooted the server
- Enabled neutron_sriov in the globals.yml file(which is used in kolla-ansible’s deployment)
- Created a physical_network_function(physnet) called sriovtenant1 which is mapped to ens3np0 port where SRIOV is enabled
- Made all the necessary changes in nova-compute(pci devices are listed passthrough_whitelist = [{“physical_network”: “sriovtenant1”, “devname”: “ens3np0”}]
- Similarlly for ml2_conf.ini
[ml2]
type_drivers = flat,vlan,vxlan,geneve
tenant_network_types = geneve
mechanism_drivers = ovn,sriovnicswitch
extension_drivers = port_security
[ml2_type_vlan]
network_vlan_ranges = sriovtenant1
[ml2_type_flat]
flat_networks = physnet1, sriovtenant1
- Enabled PCI passthrough filter in nova-scheduler
- ip link show ens3np0
root@poc-dev-3:/home/user# ip link show ens3np0
6: ens3np0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether 88:e9:a4:1f:2f:62 brd ff:ff:ff:ff:ff:ff
vf 0 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state auto, trust off, query_rss off
vf 1 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state auto, trust off, query_rss off
vf 2 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state auto, trust off, query_rss off
vf 3 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state auto, trust off, query_rss off
vf 4 link/ether fa:16:3e:e0:03:16 brd ff:ff:ff:ff:ff:ff, vlan 805, spoof checking on, link-state enable, trust off, query_rss off
vf 5 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state auto, trust off, query_rss off
vf 6 link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff, spoof checking off, link-state auto, trust off, query_rss off
vf 7 link/ether 22:56:d7:64:61:89 brd ff:ff:ff:ff:ff:ff, spoof checking on, link-state enable, trust off, query_rss off
altname enp15s0np0
- Created sriov-net and used the VLAN network type (provided the same VLAN ID where the port ens3np0 was connected to switch) and created the subnets & port with vnic type as direct
- Launched an instance using the port created from sriov-net, But there is no IP address allocated in the VM
- No IP Inside the VM
- Even Static IP allocation is also not happening
Help me resolve this issue
