memcopy fails in multiple pthreads with cudaSetDevice() i m unable to use pthread with multiple GPUs
I have S2070 with 4 GPUs and I want to run my program such that one main program spawns 4 pthreads to run kernels on 4 GPUs.
I am getting an error on cudaMemcpy() calls. I am using Red Hat linux.
Here is a program that I developed to tell my understanding of the method:
The result is shown at last…what is wrong with the way I am using pthreads to access multiGPUs ? I am using cuda 4.0.
#include <cstdlib>
#include <stdio.h>
#include "/usr/local/cuda/include/driver_functions.h"
#include </usr/local/cuda/include/cuda.h>
#include </usr/local/cuda/include/cutil.h>
#include <pthread.h>
#include <iostream>
#define NUM_THREADS 2
#define SIZE 100000
#define BLOCKSIZE SIZE/NUM_THREADS
#define divUp(A,B) ((A+B-1)/B)
using namespace std;
void* thread_work(void *param);
// A simple GPU kernel :
__global__ void add_vectors(int *a,int *b,int *x)
   int Idx = __umul24(blockIdx.x,blockDim.x) + threadIdx.x;
x[Idx] = a[Idx] + b[Idx];
typedef struct config
   int threadid;
   int start_index;
   int *vector_a;
   int *vector_b;
   int *vector_x;
}CONFIG;
int main(int argc, char** argv)
   int A;
   for(int i=0;i<SIZE;i++)
     A[i] = i;
int B;
     B[i] = i;
int X;
     X[i] = 0;
CONFIG conf[NUM_THREADS];
// create threads to allocate work :
   pthread_t thread[NUM_THREADS];  // create a thread pool (static)
   pthread_attr_t attr;
   pthread_attr_init(&attr);
   pthread_attr_setdetachstate(&attr,PTHREAD_CREATE_JOINABLE);
int rc[NUM_THREADS];
for(int i=0;i<NUM_THREADS;i++)
       conf[i].threadid = i;
       conf[i].start_index =i*BLOCKSIZE;
       conf[i].vector_a = A;
       conf[i].vector_b = B;
       conf[i].vector_x = X;
      if(rc[i] = pthread_create (&thread[i],&attr,thread_work,&conf[i]))
       printf("\n Couldnot create thread | ERROR CODE : %d",rc[i]);
       exit(EXIT_FAILURE);
        pthread_join(thread[i],NULL);
int Y;
   for(int j=0;j<SIZE;j++)
       Y[j] = A[j] + B[j];
for(int k=0;k<SIZE;k++)
       if(X[k]!=Y[k])
           cout<<"Failed at "<<k<<" : "<<X[k]<<" : "<<Y[k]<<endl;
return 0;
   CONFIG * conf = (CONFIG*) param;
int threadid = conf->threadid;
   int start_index = conf->start_index;
   int *A = conf->vector_a;
   int *B = conf->vector_b;
   int *X = conf->vector_x;
int* g_A;
   int *g_B;
   int *g_X;
//    CUDA_SAFE_CALL(cudaSetDevice(threadid));
cudaMalloc((void**)&g_A,BLOCKSIZE*sizeof(int));
   cudaMalloc((void**)&g_B,BLOCKSIZE*sizeof(int));
   cudaMalloc((void**)&g_X,BLOCKSIZE*sizeof(int));
cudaError_t error;
   error = cudaGetLastError();
   if(error!=cudaSuccess)
          cout<<"Thread "<<threadid<<" :  [FATAL ERROR] Problems in memory initialization - "<<cudaGetErrorString(error)<<endl;
          exit(0);
cudaMemcpy(&g_A,&(A[start_index]),sizeof(int)*BLOCKSIZE,cudaMemcpyHostToDevice);
   cudaMemcpy(&g_B,&(B[start_index]),sizeof(int)*BLOCKSIZE,cudaMemcpyHostToDevice);
          cout<<"Thread "<<threadid<<" : [FATAL ERROR] Problems in memory copy - "<<cudaGetErrorString(error)<<endl;
          exit(0);
dim3 nthreads(32,1);
   dim3 grid(divUp(BLOCKSIZE,nthreads.x),1);
add_vectors<<<grid,nthreads>>>(g_A,g_B,g_X);
          cout<<"Thread "<<threadid<<" :  [FATAL ERROR] Problems in kernel - "<<cudaGetErrorString(error)<<endl;
          exit(0);
cudaMemcpy(&X[start_index],&g_X,sizeof(int)*BLOCKSIZE,cudaMemcpyDeviceToHost);
          cout<<"Thread "<<threadid<<" : [FATAL ERROR] Problems in result memory copy - "<<cudaGetErrorString(error)<<endl;
          exit(0);
cout<<" thread "<<threadid<<" completed .."<<endl;
Result:
./mtgpu_vectadd
Thread 1 : [FATAL ERROR] Problems in memory copy - invalid argument
Thread 0 : [FATAL ERROR] Problems in memory copy - invalid argument
cudaMemcpy deals with pointers, not pointers to pointers. You should be passing g_A, not &g_A. (Same for g_B)
That was so silly of me…
but my actual code doesnt have an ‘&’ before the device pointers. It gives a
“segmentation fault error”… can u please tell whether my code is semantically correct?
amean can we use pthreads with cuda in this way ??
I don’t see anything obviously wrong (although I’m not sure why you commented out the cudaSetDevice line). This is how multi-GPU CUDA is usually done.
You’ll want to compile your code in host debug mode (nvcc -g) and run it in GDB so you can see which line is segfaulting.
Thanx seibert … That commenting was a typo mistake…
so i will compile in debug mode and come back here… :)
Ya…so there is no segfault in this program now … it works…until I keep everything in one file…
but the problem in real environment is this:
I have a class defined (c++) which uses all cuda functions declared as extern “C” in a .cu file. This class is invoked from the main function inside pthreads.
The problem is that in the .cu file, I have globally declared texture references for images so that it can be used inside kernel and the other functions.
Now when I invoke two threads with different datasets on two devices, the texture references are common and hence a segmentation fault happens when one thread frees up the global texture while the other is in process.
I have a design issue here… How to I seperate C++ code from a cuda code which uses texture references ???
Example:
Main calls two threads on two images with abc object:
abc.cpp uses cudaabc.cu
cudaabc.cu has a texture refenrence declared as global. …
kindly help. please ask if further clarification is required.
