Memcpy performance on Jetson AGX ORIN
I found low performance in my modules compare to before.
I checked a benchmark of memcpy.
Below table is the results.
(https://gist.githubusercontent.com/lemire/a0cfdafda7448b98fd66f47086ac65f3/raw/2b460ea4cc26597c9c54d3182e689168ce056c7e/copybenchmark.c )
build : gcc -o copybenchmark copybenchmark.c
Xavier Orin
root@zerofly-desktop:/mnt/nvidia/benchmark# ./copybenchmark root@espresso-desktop:/mnt/nvidia/benchmark/copybenchmark# ./copybenchmark
copying 1953 MB copying 1953 MB
time = 0.084000 1190.476207 millions of uints/sec time = 0.166181 601.753517 millions of uints/sec
[memcpy] time = 0.084000 3124.999852 millions of uints/sec [memcpy] time = 0.166181 3105.493661 millions of uints/sec
time = 0.084000 1190.476207 millions of uints/sec time = 0.162941 613.719099 millions of uints/sec
[memcpy] time = 0.084000 3571.428461 millions of uints/sec [memcpy] time = 0.162941 3099.237739 millions of uints/sec
[Condition]
  • MAXN
  • jetson_clocks
  • Jeton AGX ORIN (JetPack 5.0 DP)
  • cat /etc/nv_tegra_release
R34 (release), REVISION: 1.1, GCID: 30414990, BOARD: t186ref, EABI: aarch64, DATE: Tue May 17 04:20:55 UTC 2022
Is this normal in current version(DP)?
It is possible you see issues on 5.0.1 DP. Thanks for reporting it and we will check this further.
There looks to be a typo in this print:
  float t2 = (after.ru_utime.tv_usec - before.ru_utime.tv_usec) / 1000000.0;
  printf("[memcpy] time = %f  %f millions of uints/sec\n", t2,
         N * NTrials / (t2 * 1000.0 * 1000.0));
Should print out t2 instead of t. Please help check and confirm this.
And please execute sudo jetson_clocks before the profiling.
You are right. There is a bug in that opensource.
I have fixed it.
Then, below table is results.
Xavier Orin
espresso@zerofly-desktop:/mnt/nvidia/benchmark$ sudo jetson_clocks
espresso@zerofly-desktop:/mnt/nvidia/benchmark$ ./copybenchmark
copying 1953 MB
time = 0.080000 1250.000028 millions of uints/sec
[memcpy] time = 0.032000 3124.999852 millions of uints/sec
espresso@espresso-desktop:/mnt/nvidia/benchmark/copybenchmark$ sudo jetson_clocks
espresso@espresso-desktop:/mnt/nvidia/benchmark/copybenchmark$ ./copybenchmark
copying 1953 MB
time = 0.163294 612.392363 millions of uints/sec
[memcpy] time = 0.024657 4055.643451 millions of uints/sec
Exactly, Orin’s NEON accelerator is slow than Xavier. Right?
Yes, memcpy() is faster on Orin and vst1q_u32() is slower. We will check with our teams to clarify if it is expected.
Internally we have checked performance of memcpy() and it s expected that Orin has better performance. We don’t check vst1q_u32() and don’t have much experience of using it. It seems to be an experimental function per
vst1q_u32 in core::arch::arm - Rust
If calling memcpy() is fine in your use-case, we would suggest call this function instead of calling vst1q_u32()
Okay, I got it.
