According to Memcpy performance on Jetson AGX ORIN, I did the same test and the result is quite similar with the result in that topic:
d@d-desktop:~$ sudo ./copybenchmark
copying 1953 MB
time = 0.160565 622.800720 millions of uints/sec
[memcpy] time = 0.030113 3320.824846 millions of uints/sec
I noticed that the above test is based on 2 memory region generated by kmalloc.
However when I try memcpy from a kmalloc memory to a virtual memory which is generated by ioremap_wc from a iomem region, the speed will be much slower:
[ 7505.369562] Mapped BAR Phys Addr Base: 0x0000002761000000
[ 7505.369569] Mapped size: 16777216
[ 7505.369589] io_base: 0xffff800037000000
Data transferred 2097152 Bytes, time consume 1726975 ns
Transfer speed 1158 MBytes/s
Is that the real performance when accessing the iomem? If not how to fix it to an ideal speed?
Best regard.
