Memory leak, cudaMalloc, and cudaFree
Note: I’m pretty new at C++ so this might be a really easy answer.
I’m creating a code that does a simple image transformation. I am doing this process in a loop and have noticed that my code is leaking memory. I debugged it and found out the sources are the float* s I use in the cudaMalloc call (see code). When the kernel is finished I call cudaFree on the array and it frees the array on the GPU only. So each time I run the code it is creating these 2 sets of 3 arrays on the host and they are not being deleted. I tried adding delete and free calls on them (to remove the arrays on the host) but I get an Access Violation Error.
So what am I doing wrong here?
//THESE GUYS ARE THE PROBLEM
	float* tempin_gpu_r = new float[width * height];
	float* tempin_gpu_g = new float[width * height];
	float* tempin_gpu_b = new float[width * height];
	float* tempout_gpu_r = new float[width2 * height2];
	float* tempout_gpu_g = new float[width2* height2];
	float* tempout_gpu_b = new float[width2 * height2];
//Allocate memory on the GPU
	cudaMalloc((void **)(&tempin_gpu_r), (width * height) * sizeof(float));
	cudaMalloc((void **)(&tempin_gpu_g), (width * height) * sizeof(float));
	cudaMalloc((void **)(&tempin_gpu_b), (width * height) * sizeof(float));
	cudaMalloc((void **)(&tempout_gpu_r), (width2 * height2) * sizeof(float));
	cudaMalloc((void **)(&tempout_gpu_g), (width2 * height2) * sizeof(float));
	cudaMalloc((void **)(&tempout_gpu_b), (width2 * height2) * sizeof(float));
//Copy the image data from the host onto the GPU (you don't need to see this)
//Kernel Setup and Call (you don't need to see this)
//Copy the data from the GPU back to the host  (you don't need to see this)
cudaFree(tempin_gpu_r);
cudaFree(tempin_gpu_g);
cudaFree(tempin_gpu_b);
cudaFree(tempout_gpu_r);
cudaFree(tempout_gpu_g);
cudaFree(tempout_gpu_b);
need to add delete tempin_gpu_r;
If it does not work, loos like you spoiled memory.
Ah, you do not need to call operator new, only need float* tempin_gpu_r ;
you need to allocate memory twice on cpu and gpu with different pointers and copy memory back from gpu to allocated memory using cudaMemcpy.
I’m not sure I understand. If I add “delete tempin_gpu_r;” after my cudaFree calls, I get the Access Violation Reading error.
My GPU<-> host calls should be good:
cudaMemcpy(tempin_gpu_r, tempin_cpu_r, (width * height) * sizeof(float), cudaMemcpyHostToDevice);
cudaMemcpy(tempout_cpu_r, tempout_gpu_r, (width2 * height2) * sizeof(float), cudaMemcpyDeviceToHost);
You are using same pointer to allocate memory on device and host.
it is memory allocation, remove it.
Where is tempin_cpu_r defined?
