Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
[*] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] other
SDK Manager Version
1.9.3.10904
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
I’m using the CUDA runtime library and I’m seeing a memory leak.
The code is as follows:
int main(int argc, char** argv) {
cudaSetDevice(0);
cudaStream_t stream=nullptr;
cudaStreamCreate(&stream);
cudaStreamDestroy(stream);
cudaDeviceSynchronize();
cudaError cuda_error=cudaDeviceReset();
if(cuda_error!=cudaSuccess){
std::cerr<<“cudaDeviceReset Error :”<<cuda_error;
return 0;
test cmd:
/opt/data/haihuawei/valgrind/bin/valgrind --tool=memcheck --leak-check=full --log-file=valgrind.log.txt ./cuda_test
log:
==311760== 8 bytes in 1 blocks are definitely lost in loss record 23 of 1,475
==311760== at 0x484B828: malloc (vg_replace_malloc.c:442)
==311760== by 0x2E98EC4F: ??? (in /usr/lib/libnvcucompat.so)
==311760== by 0x74EEBD7: ??? (in /usr/lib/libcuda.so.1)
==311760== by 0x7516CE7: ??? (in /usr/lib/libcuda.so.1)
==311760== by 0x74EF043: ??? (in /usr/lib/libcuda.so.1)
==311760== by 0x7371717: ??? (in /usr/lib/libcuda.so.1)
==311760== by 0x741E50B: ??? (in /usr/lib/libcuda.so.1)
==311760== by 0x750C72B: ??? (in /usr/lib/libcuda.so.1)
==311760== by 0x878BFBF: ??? (in /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcudart.so.11.4.291)
==311760== by 0x878EB93: ??? (in /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcudart.so.11.4.291)
==311760== by 0x8E8ADF3: __pthread_once_slow (pthread_once.c:116)
==311760== by 0x87D3613: ??? (in /usr/local/cuda-11.4/targets/aarch64-linux/lib/libcudart.so.11.4.291)
==311760==
==311760== 12 bytes in 1 blocks are definitely lost in loss record 25 of 1,475
==311760== by 0x2E98EC2F: ??? (in /usr/lib/libnvcucompat.so)
==311760==
Dear @haihua.wei,
Below is the output observed on my machine.
nvidia@tegra-ubuntu:/usr/local/cuda/samples/0_Simple/simpleCUDATest$ cat simpleCUDATest.cu
#include <cuda_runtime.h>
// includes, project
#include <helper_cuda.h>
#include <helper_functions.h>
cudaSetDevice(0);
std::cerr<< "cudaDeviceReset Error :"<<cuda_error;
return 0;
nvidia@tegra-ubuntu:/usr/local/cuda/samples/0_Simple/simpleCUDATest$ valgrind --tool=memcheck --leak-check=full --log-file=/home/nvidia/valgrind.log.txt ./simpleCUDATest
Illegal instruction
nvidia@tegra-ubuntu:/usr/local/cuda/samples/0_Simple/simpleCUDATest$ cat ~/valgrind.log.txt
==10016== Memcheck, a memory error detector
==10016== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==10016== Using Valgrind-3.15.0 and LibVEX; rerun with -h for copyright info
==10016== Command: ./simpleCUDATest
==10016== Parent PID: 9795
==10016==
ARM64 front end: load_store
disInstr(arm64): unhandled instruction 0xB8A18001
disInstr(arm64): 1011'1000 1010'0001 1000'0000 0000'0001
==10016== valgrind: Unrecognised instruction at address 0x53d8398.
==10016== at 0x53D8398: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x543F713: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x543FD43: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x53D34D3: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x13868B: __cudart106 (in /usr/local/cuda-11.4/samples/0_Simple/simpleCUDATest/simpleCUDATest)
==10016== by 0x1387EB: __cudart917 (in /usr/local/cuda-11.4/samples/0_Simple/simpleCUDATest/simpleCUDATest)
==10016== by 0x48A23B7: __pthread_once_slow (pthread_once.c:116)
==10016== by 0x187C17: __cudart1189 (in /usr/local/cuda-11.4/samples/0_Simple/simpleCUDATest/simpleCUDATest)
==10016== by 0x12EDB3: __cudart104 (in /usr/local/cuda-11.4/samples/0_Simple/simpleCUDATest/simpleCUDATest)
==10016== by 0x156447: cudaSetDevice (in /usr/local/cuda-11.4/samples/0_Simple/simpleCUDATest/simpleCUDATest)
==10016== by 0x11140B: main (in /usr/local/cuda-11.4/samples/0_Simple/simpleCUDATest/simpleCUDATest)
==10016== Your program just tried to execute an instruction that Valgrind
==10016== did not recognise. There are two possible reasons for this.
==10016== 1. Your program has a bug and erroneously jumped to a non-code
==10016== location. If you are running Memcheck and you just saw a
==10016== warning about a bad jump, it's probably your program's fault.
==10016== 2. The instruction is legitimate but Valgrind doesn't handle it,
==10016== i.e. it's Valgrind's fault. If you think this is the case or
==10016== you are not sure, please let us know and we'll try to fix it.
==10016== Either way, Valgrind will now raise a SIGILL signal which will
==10016== probably kill your program.
==10016==
==10016== Process terminating with default action of signal 4 (SIGILL)
==10016== Illegal opcode at address 0x53D8398
==10016==
==10016== HEAP SUMMARY:
==10016== in use at exit: 80,990 bytes in 56 blocks
==10016== total heap usage: 81 allocs, 25 frees, 292,782 bytes allocated
==10016==
==10016== 56 bytes in 1 blocks are possibly lost in loss record 7 of 18
==10016== at 0x4849D8C: malloc (in /usr/lib/aarch64-linux-gnu/valgrind/vgpreload_memcheck-arm64-linux.so)
==10016== by 0x51FCB8F: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x51F27F3: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x51DC1AB: ??? (in /usr/lib/libcuda.so.1)
==10016== by 0x400E8B3: call_init.part.0 (dl-init.c:72)
==10016== by 0x400E9B3: call_init (dl-init.c:30)
==10016== by 0x400E9B3: _dl_init (dl-init.c:119)
==10016== by 0x4BC620B: _dl_catch_exception (dl-error-skeleton.c:182)
==10016== by 0x4012A13: dl_open_worker (dl-open.c:758)
==10016== by 0x4BC61AB: _dl_catch_exception (dl-error-skeleton.c:208)
==10016== by 0x40121A3: _dl_open (dl-open.c:837)
==10016== by 0x48C409B: dlopen_doit (dlopen.c:66)
==10016==
==10016== 336 bytes in 6 blocks are possibly lost in loss record 14 of 18
==10016== by 0x51F2753: ??? (in /usr/lib/libcuda.so.1)
==10016==
==10016== LEAK SUMMARY:
==10016== definitely lost: 0 bytes in 0 blocks
==10016== indirectly lost: 0 bytes in 0 blocks
==10016== possibly lost: 392 bytes in 7 blocks
==10016== still reachable: 80,598 bytes in 49 blocks
==10016== suppressed: 0 bytes in 0 blocks
==10016== Reachable blocks (those to which a pointer was found) are not shown.
==10016== To see them, rerun with: --leak-check=full --show-leak-kinds=all
==10016==
==10016== For lists of detected and suppressed errors, rerun with: -s
==10016== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 0 from 0)
I don’t see definitely lost messages in log.
@SivaRamaKrishnaNV What your machine is like in a Drive OS and CUDA environment. Can you give us a reference?
Dear @haihua.wei,
Yes. I quickly tested on DRIVE AGX Orin platform with DRIVE OS(latest internal release).
I will try with recent devzone release and update you the results
@SivaRamaKrishnaNV It’s been a huge help to us. Thank you so much.
