Memory leak problem when using nvds_obj_enc_process
• Hardware Platform (Jetson / GPU): Quadro RTX 4000
• DeepStream Version: 6.0.1
• TensorRT Version: 8.4.1.5
• NVIDIA GPU Driver Version (valid for GPU only): 510.47.03
I use nvds_obj_enc_process to do jpeg encode. After a day of running a program, it crashed due to leak memory. I profiled the program using LeakSanitizer tool and found out that it is the nvds_obj_enc_process that caused leak memory. Is there a patch to fix this issue?
Could you attach the detailed steps of LeakSanitier and the memory data that monitored?
I experimented on the deepstream_image_meta_test sample. I used CMakeLists to compile the project with additional option
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -Wall -fno-omit-frame-pointer -fsanitize=leak -g -pthread")
to enable LeakSanitizer profiler. The result is shown below indicating that there is a direct leak in nvds_obj_enc_process
==18434==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 6656 byte(s) in 26 object(s) allocated from:
    #0 0x7fc4710e2acb in __interceptor_malloc (/usr/lib/x86_64-linux-gnu/liblsan.so.0+0xeacb)
    #1 0x7fc456fcb8ed  (/usr/lib/x86_64-linux-gnu/libfontconfig.so.1+0x1d8ed)
Direct leak of 520 byte(s) in 13 object(s) allocated from:
    #1 0x7fc3a926afe1  (<unknown module>)
Direct leak of 216 byte(s) in 1 object(s) allocated from:
    #0 0x7fc4710e37e3  (/usr/lib/x86_64-linux-gnu/liblsan.so.0+0xf7e3)
    #1 0x7fc4532672a7  (/usr/lib/x86_64-linux-gnu/libnvparsers.so.8.4.1+0x32a7)
    #2 0x31d6ffffffff  (<unknown module>)
Direct leak of 192 byte(s) in 1 object(s) allocated from:
    #1 0x7fc4708bda85 in allocate_buffers (/opt/nvidia/deepstream/deepstream/lib/libnvds_batch_jpegenc.so+0x1a85)
    #2 0x7fc4708be2fd in nvds_obj_enc_process (/opt/nvidia/deepstream/deepstream/lib/libnvds_batch_jpegenc.so+0x22fd)
    #3 0x563b3141d888 in pgie_src_pad_buffer_probe /home/martin/minhbq6/checkLeakMem/main.cpp:241
    #4 0x7fc46fc7b287  (/usr/lib/x86_64-linux-gnu/libgstreamer-1.0.so.0+0x74287)
Direct leak of 184 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9251b54  (<unknown module>)
Direct leak of 112 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9261b3b  (<unknown module>)
Direct leak of 100 byte(s) in 3 object(s) allocated from:
    #1 0x7fc3a9262b2e  (<unknown module>)
Direct leak of 40 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9264a33  (<unknown module>)
Direct leak of 24 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9264931  (<unknown module>)
Direct leak of 8 byte(s) in 1 object(s) allocated from:
    #0 0x7fc4710e2c73 in realloc (/usr/lib/x86_64-linux-gnu/liblsan.so.0+0xec73)
    #1 0x7fc3a9261811  (<unknown module>)
    #1 0x7fc4517b526c  (<unknown module>)
Indirect leak of 7135 byte(s) in 13 object(s) allocated from:
    #1 0x7fc3a9264d7c  (<unknown module>)
Indirect leak of 1632 byte(s) in 51 object(s) allocated from:
    #1 0x7fc456fcbfd8  (/usr/lib/x86_64-linux-gnu/libfontconfig.so.1+0x1dfd8)
Indirect leak of 808 byte(s) in 2 object(s) allocated from:
    #1 0x7fc3a9264b4d  (<unknown module>)
Indirect leak of 736 byte(s) in 4 object(s) allocated from:
Indirect leak of 519 byte(s) in 50 object(s) allocated from:
    #1 0x7fc46f2f6a29 in __strdup (/lib/x86_64-linux-gnu/libc.so.6+0x9da29)
Indirect leak of 264 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a924667d  (<unknown module>)
Indirect leak of 240 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9243a57  (<unknown module>)
    #2 0x7ffffffff  (<unknown module>)
Indirect leak of 232 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9260bdf  (<unknown module>)
Indirect leak of 224 byte(s) in 4 object(s) allocated from:
    #1 0x7fc3a924b35d  (<unknown module>)
Indirect leak of 176 byte(s) in 2 object(s) allocated from:
    #1 0x7fc3a9259b1a  (<unknown module>)
Indirect leak of 160 byte(s) in 4 object(s) allocated from:
Indirect leak of 128 byte(s) in 2 object(s) allocated from:
    #1 0x7fc3a92610b8  (<unknown module>)
Indirect leak of 112 byte(s) in 6 object(s) allocated from:
    #1 0x7fc3a9264fc3  (<unknown module>)
Indirect leak of 112 byte(s) in 1 object(s) allocated from:
Indirect leak of 96 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a92566ff  (<unknown module>)
Indirect leak of 96 byte(s) in 2 object(s) allocated from:
    #1 0x7fc3a926b101  (<unknown module>)
Indirect leak of 80 byte(s) in 2 object(s) allocated from:
    #1 0x7fc3a926af8a  (<unknown module>)
Indirect leak of 64 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a92569dd  (<unknown module>)
    #2 0xeb5c5c5f623a02ff  (<unknown module>)
    #1 0x7fc3a92584d7  (<unknown module>)
Indirect leak of 48 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9246637  (<unknown module>)
    #1 0x7fc3a9246648  (<unknown module>)
Indirect leak of 48 byte(s) in 2 object(s) allocated from:
Indirect leak of 42 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9265289  (<unknown module>)
Indirect leak of 24 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a92588b2  (<unknown module>)
    #1 0x7fc3a9264995  (<unknown module>)
    #1 0x7fc3a9244601  (<unknown module>)
Indirect leak of 16 byte(s) in 1 object(s) allocated from:
    #1 0x7fc3a9261981  (<unknown module>)
Indirect leak of 7 byte(s) in 1 object(s) allocated from:
SUMMARY: LeakSanitizer: 21299 byte(s) leaked in 211 allocation(s).
About this detect result, How long did you run the deepstream_image_meta_test?
We fix some memory leak problems in the latest version, could you update it?
If there is still a memory leak problem, you can attach your CMake file and we’ll debug for it. Thanks
I ran an one minute long video to get this result. Here’s my CMakeLists.txt file
cmake_minimum_required(VERSION 3.15 FATAL_ERROR)
set(CMAKE_CXX_STANDARD 17)
set(CMAKE_CXX_STANDARD_REQUIRED True)
set(CMAKE_CUDA_COMPILER /usr/local/cuda-11.5/bin/nvcc)
project(checkLeakMem LANGUAGES CXX CUDA)
# set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -O3 -Wall -pthread")
find_package(PkgConfig REQUIRED)
add_executable(${PROJECT_NAME} main.cpp)
pkg_check_modules(Uuid REQUIRED IMPORTED_TARGET uuid)
include_directories(${Uuid_INCLUDE_DIRS})
target_link_libraries(${PROJECT_NAME} ${Uuid_LIBRARIES})
# cuda
find_package(CUDA REQUIRED)
set(CMAKE_CUDA_ARCHITECTURES 52 60 61 75 CACHE STRING "CUDA architectures")
set_target_properties(${PROJECT_NAME} PROPERTIES CUDA_STANDARD 17)
set(CMAKE_CUDA_FLAGS "${CMAKE_CUDA_FLAGS} -O3 --compiler-options -fno-strict-aliasing --ptxas-options=-v --generate-line-info")
include_directories(${CUDA_INCLUDE_DIRS})
target_link_libraries(${PROJECT_NAME} ${CUDA_LIBRARIES})
# gstreamer
pkg_check_modules(GST_PKG REQUIRED IMPORTED_TARGET gstreamer-app-1.0)
target_include_directories(${PROJECT_NAME} PUBLIC ${GST_PKG_INCLUDE_DIRS})
target_link_libraries(${PROJECT_NAME} PkgConfig::GST_PKG)
target_compile_options(${PROJECT_NAME} PUBLIC ${GST_PKG_CFLAGS_OTHER})
# deepstream
target_include_directories(${PROJECT_NAME} PUBLIC /opt/nvidia/deepstream/deepstream/sources/includes)
target_link_directories(${PROJECT_NAME} PUBLIC /opt/nvidia/deepstream/deepstream/lib)
target_link_libraries(${PROJECT_NAME} -lnvbufsurface -lnvbufsurftransform -lnvdsgst_helper -lnvds_batch_jpegenc
                                        -lnvdsgst_meta -lnvds_meta -lnvinfer -lnvinfer_plugin -lnvds_inferutils
                                        -lnvds_utils -lm -lnvds_infercustomparser)
# OpenCV
find_package(OpenCV REQUIRED)
include_directories(${OpenCV_INCLUDE_DIRS})
target_link_libraries(${PROJECT_NAME} ${OpenCV_LIBS})
target_link_libraries(${PROJECT_NAME} -lstdc++fs -lcurl)
# Json-glib
pkg_check_modules(JSON-GLIB REQUIRED json-glib-1.0)
include_directories(${JSON-GLIB_INCLUDE_DIRS})
target_link_libraries(${PROJECT_NAME} ${JSON-GLIB_LIBRARIES})
You can run several times, like half a hour, one hour. We can make comparative analysi.
Also , you can use our memory test below to attach the result. Thanks.
https://forums.developer.nvidia.com/t/deepstream-sdk-faq/80236/14
The one-minute video is just an example for me to post the question here. Actually, I have another application that runs on rtsp streams. The program run overnight for like 12 hours and RAM used rose to 61GB
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
Just from the memory leak log, the libfontconfig.so.1 got the most memory leaks(6656 B). Our nvds_obj_enc_process code have no memory leak problem. It requests memory in allocate_buffers for a memory pool, but release it in another module. I think the LeakSanitizer may have some problems in statistics in this conditions.
We suggest you update your deepstream to 6.1.1 which we have fixed some memory leak problems already. Also, you can use the method I attached to test the memory problems.
