memory problem on tesla c1060
Hi All;
I have a problem with a program using cufft in it.
[codebox]#include // original
#include “main.h”
using namespace std;
int main(int argc, char *argv)
    int NX, NY, NZ; // define the fft limits
// fft limits
     NX= 64;
     NY= 64;
     NZ= 128;
    int NXYZ; // define the fft limits
    NXYZ = NX* NY* NZ; // defining more spaces than required is possible
cout << " NXYZ " << NXYZ << endl;
cufftComplex data[NXYZ], data_1[NXYZ]; // data variables on the cpu
// GPU memory allocation 3d
    cudaMalloc((void**)&devPtr, sizeof(cufftComplex)*(NX*NY*NZ));
	cudaMalloc((void**)&devPtr_1, sizeof(cufftComplex)*NX*NY*NZ);
/* creates 3D FFT plan */
    cufftPlan3d(&plan, NX, NY, NZ, CUFFT_C2C);
    cufftPlan3d(&plan_1, NX, NY, NZ, CUFFT_C2C);
// source data creation or fill the vector
    for(i=  0 ; i < NX*NY*NZ ; i++){
        // data part 1
            data[i].x = 2.0f; // real part
            data[i].y = 1.0f; // imag part
		// data part 2
            data_1[i].x = 4.0f;
            data_1[i].y = 5.0f;
// transfer to GPU memory _
    cudaMemcpy(devPtr, data, sizeof(cufftComplex)*NX*NY*NZ, cudaMemcpyHostToDevice);
    cudaMemcpy(devPtr_1, data_1, sizeof(cufftComplex)*NX*NY*NZ, cudaMemcpyHostToDevice);
/* executes FFT processes */
    cufftExecC2C(plan, devPtr, devPtr, CUFFT_FORWARD);
    cufftExecC2C(plan_1, devPtr_1, devPtr_1, CUFFT_FORWARD);
/* executes FFT processes (inverse transformation) */
    cufftExecC2C(plan, devPtr, devPtr, CUFFT_INVERSE);
    cufftExecC2C(plan_1, devPtr_1, devPtr_1, CUFFT_INVERSE);
/* transfer results from GPU memory */
    cudaMemcpy(data, devPtr, sizeof(cufftComplex)*NX*NY*NZ, cudaMemcpyDeviceToHost);
    cudaMemcpy(data_1, devPtr_1, sizeof(cufftComplex)*NX*NY*NZ, cudaMemcpyDeviceToHost);
/* deletes CUFFT plan */
    cufftDestroy(plan);
    cufftDestroy(plan_1);
/* frees GPU memory */
    cudaFree(devPtr);
    cudaFree(devPtr_1);
for(i = 0 ; i < NXNYNZ ; i += 10000){
cout << "data " << i << " "<< data[i].x << " "<< data[i].y << " "
              << "data_1 " << i << " "<< data_1[i].x << " "<< data_1[i].y
              << endl;
return 0;
}[/codebox]
The program running good on a card and system with the following specs:
Centos 5.3; GeForce 9800 GT; code::Blocks 8.02; gcc 4.1.2; cuda 2.3
But when I run it on another machine with this specs
Ubuntu 9.04; tesla c1060; cuda 2.3
the system throughs the segmentation error. :blink:
Segmentation fault
the code I am using on this last machine is
#include “main.h”
cudaSetDevice(0);
// fft limits
     NX= 64;
     NY= 64;
     NZ= 128;
        // data part 1
		// data part 2
            data_1[i].x = 4.0f;
            data_1[i].y = 5.0f;
    cufftDestroy(plan);
    cudaFree(devPtr);
    cudaFree(devPtr_1);
              << endl;
return 0;
[/codebox]
I add the cudaSetDevice(0); to insure that I am using the first device (c1060) not the integrated one (nForce 980a)
As far as I know; c1060 has 8 time the memory of the 9800 GT.
Any Idea what is going on?
these are the contents of main.h
#include <cuda.h>
#include <cuda_runtime.h>
#include <cufft.h>
cufftHandle plan, plan_1;
cufftComplex *devPtr, *devPtr_1; // pointers for data on the gpu
First dumb question, you’re hardwiring the device number into your program? Why?
And are you absolutely sure that device 0 is your Tesla?
You can check really easily. And in fact this is a good status message in your program no matter what.
CUDA_SAFE_CALL_NO_SYNC(cudaGetDeviceProperties(&deviceProp, device));
  fprintf(stderr, "Using device %d: %s\n", device, deviceProp.name);
SPWorley
Thanks for having a look;
To be sure before I post my problem I did the following:
first: I run devicequery to check for the device,
second: I selected cudaSetDevice(1) which the integrated device and the size of NXYZ that was able to run on it is far smaller than cudaSetDevice(0),
third thing I did is to remove the manual selection of gpu and replace it with a small piece of code that searches for devices on the host and return as an argument to cudaSetDevice() the gpu with the max # of multiprocessors.
and still it shows the same bad results!
any ideas?
I test your code, and modify your code as
cufftComplex *data, *data_1;
data = (cufftComplex*) malloc( sizeof(cufftComplex)*NXYZ );
assert( data ) ;
data_1 = (cufftComplex*) malloc( sizeof(cufftComplex)*NXYZ );
assert( data_1 ) ;
just using dynamic allocation
then the program works without any error.
However if I use
cufftComplex data[524288], data_1[524288];
where NXYZ = NX* NY* NZ = 6464128 = 524288, say size(data) = size(data_1) = 4 MB
then vc2005 says stack overflow
I think this is stack-overflow problem.
by the way, how could you compile your original code,
it should report error at
since NXYZ is not a constant expression
LSChien
Thanks for your input,
Based on your suggestions I have the program working fine now. External Media
For the cufftComplex data[524288], data_1[524288];
I define them in the source file not in the header, I am using gcc as a compiler and it gives me no errors.
