I installed successfully MLNX_OFED_LINUX-2.2-1.0.1-rhel6.4-x86_64 on rhel6.4 machine with kernel 2.6.32-358.46.2.el6.x86_64.
Then I started two daemons
1.)/etc/init.d/openibd
2.)/etc/init.d/opensmd
If opensm was able to setup the subnet correctly then message “SUBNET UP” should seen in log files /var/log/opensm.log and /var/log/messages which is not found.
The log file /var/log/opensm.log contains :
Aug 11 02:26:50 235789 [4C8AF700] 0x03 → OpenSM 4.1.5.MLNX20140424.25abcb5
Aug 11 02:26:50 235869 [4C8AF700] 0x80 → OpenSM 4.1.5.MLNX20140424.25abcb5
Using default GUID 0xf4521403002abf01
Entering DISCOVERING state
Aug 11 02:26:50 242489 [4C8AF700] 0x02 → osm_vendor_init: 1000 pending umads specified
Aug 11 02:26:50 264138 [4C8AF700] 0x80 → Entering DISCOVERING state
Entering STANDBY state
Aug 11 02:26:50 276494 [4C8AF700] 0x02 → osm_vendor_bind: Mgmt class 0x81 binding to port GUID 0xf4521403002abf01
Aug 11 02:26:50 340494 [4C8AF700] 0x02 → osm_vendor_bind: Mgmt class 0x03 binding to port GUID 0xf4521403002abf01
Aug 11 02:26:50 340559 [4C8AF700] 0x02 → osm_vendor_bind: Mgmt class 0x04 binding to port GUID 0xf4521403002abf01
Aug 11 02:26:50 340628 [4C8AF700] 0x02 → osm_vendor_bind: Mgmt class 0x21 binding to port GUID 0xf4521403002abf01
Aug 11 02:26:50 340700 [4C8AF700] 0x02 → osm_opensm_bind: Setting IS_SM on port 0xf4521403002abf01
Aug 11 02:26:50 368521 [45AA2700] 0x80 → Entering STANDBY state
Aug 11 02:31:50 370767 [43C9F700] 0x01 → log_rcv_cb_error: ERR 3111: Received MAD with error status = 0xC
SubnGetResp(SMInfo), attr_mod 0x0, TID 0x12f9
Initial path: 0,1,23 Return path: 0,4,1
Aug 11 02:32:00 370839 [43C9F700] 0x01 → log_rcv_cb_error: ERR 3111: Received MAD with error status = 0xC
SubnGetResp(SMInfo), attr_mod 0x0, TID 0x12fa
Aug 11 02:32:10 370884 [43C9F700] 0x01 → log_rcv_cb_error: ERR 3111: Received MAD with error status = 0xC
SubnGetResp(SMInfo), attr_mod 0x0, TID 0x12fb
It shows only two status STANDBY or DISCOVERY.What should I need to do make SUBNET UP status??
Do I requires to configure opensm manually?? But file /etc/sysconfig/opensm is also missing.
osmtest also results in a failure. :
Command Line Arguments
Done with args
Flow = All Validations
Aug 11 03:28:40 177806 [53627700] 0x7f → Setting log level to: 0x03
Aug 11 03:28:40 177956 [53627700] 0x02 → osm_vendor_init: 1000 pending umads specified
using default guid 0xf4521403002abf01
Aug 11 03:28:40 220980 [53627700] 0x02 → osm_vendor_bind: Mgmt class 0x03 binding to port GUID 0xf4521403002abf01
Aug 11 03:28:40 285077 [53627700] 0x02 → osmtest_validate_sa_class_port_info:
SA Class Port Info:
base_ver:1
class_ver:2
cap_mask:0x2602
cap_mask2:0x3E8
resp_time_val:0x10
Aug 11 03:28:40 285105 [53627700] 0x01 → osmtest_create_db: ERR 0130: Unable to open inventory file (osmtest.dat)
Aug 11 03:28:40 285114 [53627700] 0x01 → osmtest_run: ERR 0145: Database creation failed (IB_ERROR)
OSMTEST: TEST “All Validations” FAIL
Is anything went wrong in my installation??
