Microsoft Azure
I deployed a virtual machine on Microsoft Azure, with Windows Server 2016 , a Tesla M60 and I installed nvidia 385.54-tesla-desktop-winserver2016-international drivers, with VulkanSDK 1.0.61.1.
If I try to launch any sample from the SDK in Bin folder, a pop window show an error with : “VkEnumeratePhysicalDevices reported zero accesible devices” .
I already tried to contact Azure support, but they were unable to help me. Do you guys have any idea, how to resolve this issues ?
Thanks in advance.
Here is my logs
VULKAN INFO
Vulkan API Version: 1.0.61
INFO: [loader] Code 0 : loaderGetRegistryFiles: opening device VMBUS\{da0a7802-e377-4aac-8e77-0558eb1073f8}\{5620e0c7-8062-4dce-aeb7-520c7ef76171}
INFO: [loader] Code 0 : loaderGetDeviceRegistryEntry: Device ID(1) Does not contain a value for "VulkanExplicitLayers"
INFO: [loader] Code 0 : loaderGetRegistryFiles: Opening child device 2 - DISPLAY\DEFAULT_MONITOR&1A097CD8&1&UID5527112
INFO: [loader] Code 0 : loaderGetRegistryFiles: opening device PCI\VEN_10DE&DEV_13F2&SUBSYS_115E10DE&REV_A1&325097f7&0&0
INFO: [loader] Code 0 : loaderGetDeviceRegistryEntry: Device ID(3) Does not contain a value for "VulkanExplicitLayers"
INFO: [loader] Code 0 : loaderGetRegistryFiles: unable to open child-device error:13
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_api_dump.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_core_validation.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_device_simulation.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_monitor.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_object_tracker.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_parameter_validation.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_screenshot.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_standard_validation.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_threading.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_unique_objects.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\VulkanSDK.0.61.1\Bin\VkLayer_vktrace_layer.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ExplicitLayers"
INFO: [loader] Code 0 : loaderGetDeviceRegistryEntry: Device ID(1) Does not contain a value for "VulkanImplicitLayers"
INFO: [loader] Code 0 : loaderGetDeviceRegistryEntry: Device ID(3) Does not contain a value for "VulkanImplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\Windows\system32\nv-vk64.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ImplicitLayers"
INFO: [loader] Code 0 : Located json file "C:\Program Files\RenderDoc\renderdoc.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ImplicitLayers"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_api_dump.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_core_validation.json, version "1.1.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_device_simulation.json, version "1.1.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_monitor.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_object_tracker.json, version "1.1.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_parameter_validation.json, version "1.1.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_screenshot.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_standard_validation.json, version "1.1.1"
INFO: [loader] Code 0 : Encountered meta-layer VK_LAYER_LUNARG_standard_validation
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_threading.json, version "1.1.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_unique_objects.json, version "1.1.0"
INFO: [loader] Code 0 : Found manifest file C:\VulkanSDK.0.61.1\Bin\VkLayer_vktrace_layer.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file C:\Windows\system32\nv-vk64.json, version "1.0.0"
INFO: [loader] Code 0 : Found manifest file C:\Program Files\RenderDoc\renderdoc.json, version "1.0.0"
INFO: [loader] Code 0 : Meta-layer VK_LAYER_LUNARG_standard_validation all 5 component layers appear to be valid.
INFO: [loader] Code 0 : loaderGetDeviceRegistryEntry: Device ID(1) Does not contain a value for "VulkanDriverName"
INFO: [loader] Code 0 : loaderGetDeviceRegistryEntry: Device ID(3) Does not contain a value for "VulkanDriverName"
INFO: [loader] Code 0 : Located json file "C:\Windows\system32\nv-vk64.json" from registry "HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\Drivers"
INFO: [loader] Code 0 : Found ICD manifest file C:\Windows\system32\nv-vk64.json, version "1.0.0"
INFO: [loader] Code 0 : Insert instance layer VK_LAYER_NV_optimus (C:\Windows\system32\.\nvoglv64.dll)
Instance Extensions:
Instance Extensions     count = 11
        VK_EXT_debug_report                 : extension revision  6
        VK_EXT_display_surface_counter      : extension revision  1
        VK_KHR_get_physical_device_properties2: extension revision  1
        VK_KHR_get_surface_capabilities2    : extension revision  1
        VK_KHR_surface                      : extension revision 25
        VK_KHR_win32_surface                : extension revision  5
        VK_KHX_device_group_creation        : extension revision  1
        VK_KHR_external_fence_capabilities  : extension revision  1
        VK_KHR_external_memory_capabilities : extension revision  1
        VK_KHR_external_semaphore_capabilities: extension revision  1
        VK_NV_external_memory_capabilities  : extension revision  1
C:\Users\david\.jenkins\workspace\LoaderAndValidationLayers\demos\vulkaninfo.c:1662: failed with VK_ERROR_INITIALIZATION_FAILED
