Hi I’m using pgCC 6.0.4 with Suse Enterprise 9.1 on opteron and I keep running into problems with -Mipa.
First things first. Compiling with -g and -Mipa cause pgCC to fail in the link step. For some reason my file input routines get messed by ipa so I’d like to be able to find out why. However, the -g with any combination of ipa flags causes the problems below.
pgCC -o dev -I./Inc -B -O0 -Mipa -g ./Ohmtestmain.o ./Multigrid.o ./ParticleStore.o ./Structure.o ./ContactRegion.o ./Multigrid2.o ./Flux.o ./Molecule.o ./Coefficient.o ./Grid3d.o ./Grid3d2.o ./VectorArray.o ./IntArray.o ./myArray.o ./CloneStore.o ./Matrix.o ./Atom.o ./AtomList.o ./Timer.o ./Particle.o ./DeadParticle.o ./Vector.o ./myRandom.o ./FileOP.o ./CoupledIndexStore.o ./SimConfig.o ./Estimator.o ./Trajectory.o ./CmdLine.o ./InputMolecule.o ./Parallel.o -L ./ -lm -lrt
pgCC-Info-Switch -Mipa forces -O2
IPA: no IPA optimizations for 7 source files
IPA: Recompiling ./Ohmtestmain.o: new IPA information
pgCC-Fatal-/usr/local/Cluster-Apps/pgi/6.0-4/linux86-64/6.0/bin/pgcpp2 TERMINATED by signal 11
Arguments to /usr/local/Cluster-Apps/pgi/6.0-4/linux86-64/6.0/bin/pgcpp2
/usr/local/Cluster-Apps/pgi/6.0-4/linux86-64/6.0/bin/pgcpp2 Src/Ohmtestmain.cpp -debug -x 120 0x200 -opt 2 -terse 1 -inform warn -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 19 0x400000 -quad -x 120 0x80000000 -x 59 4 -y 80 0x1000 -x 80 0x10800000 -astype 0 -fn Src/Ohmtestmain.cpp -il /Ohmtestmain.il -x 123 4 -x 89 2155874370 -x 66 0x20000 -x 14 0x104 -y 89 0x40 -ipaexport /tmp/xxipaaaaaabxsaj.x -ipaimport -ipafile ./Ohmtestmain.ipa -y 89 2 -y 14 16 -x 14 32 -x 89 0x40 -x 66 0x20000000 -cmdline '+pgCC Src/Ohmtestmain.cpp -c -B -O0 -Mipa -g -o Ohmtestmain.o -c --XIPAimport /tmp/xxipaaaaaabxsaj.x ./Ohmtestmain.ipa -o ./Ohmtestmain_ipa3_dev.o' -asm /tmp/pgCCaaaaaeDsak.s
child process exit status 127: /usr/local/Cluster-Apps/pgi/6.0-4/linux86-64/6.0/bin/pgCC
make: *** [dev] Error 2
Secondly when attemting to compile C++ code with -Mipa=fast the compiler hangs.
Any ideas anyone ? I’ve tried all of the various IPA options and no one of them appears to cause the problem. It appears to be the combination that are used in -Mipa=fast (-Mipa=align,arg,const,f90ptr,shape,globals,localarg,ptr).
