MIPI camera connection failed in deepstream-app
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.0
• JetPack Version (valid for Jetson only) 4.6
• TensorRT Version 8.0.1
• Issue Type( questions, new requirements, bugs) questions
Hello.
I tried to use a MIPI camera using deepstream-app.
The execution command is as follows.
deepstream-app -c /opt/nvidia/deepstream/deepstream-6.0/samples/configs/tao_pretrained_models/deepstream_app_source1_trafficcamnet.txt
The source of the configuration is as follows.
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=1
num-sources=1
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
camera-v4l2-dev-node=0
gpu-id=0
However, the following error occurs.
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
streaming stopped, reason not-negotiated (-4)
** INFO: <bus_callback:160>: incorrect camera parameters provided, please provide supported resolution and frame rate
** INFO: <bus_callback:217>: Received EOS. Exiting …
Quitting
[NvMultiObjectTracker] De-initialized
App run failed
The information of the camera is as follows.
v4l2-ctl -d /dev/video0 --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘RG10’
Name : 10-bit Bayer RGRG/GBGB
Size: Discrete 3264x2464
Interval: Discrete 0.048s (21.000 fps)
Size: Discrete 3264x1848
Interval: Discrete 0.036s (28.000 fps)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Size: Discrete 1640x1232
Interval: Discrete 0.017s (60.000 fps)
I would appreciate it if you could tell me which part I should modify to use this camera.
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, framerate=30/1, format=NV12’ ! nvv4l2h264enc ! h264parse ! splitmuxsink location=output%02d.mp4 max-size-time=60000000000
The above pipeline works well.
Can’t nvarguscamerasrc be used instead of nv4l2src in deepstream-app?
yes , please refer to the following setting:
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP 5=CSI
type=5
camera-width=1920
camera-height=1080
camera-fps-n=30
camera-fps-d=1
Thank you! The problem has been resolved.
