Continuing the conversation from this thread. Mipi csi-2 on the jetson orin nx - #7 by a.knapper
In summary, my group is trying to bringup the orin nx 16gb in a custom cca to receive video over csi-2. x4 lanes, over CSI0 and CSI1.
It appears we’ve setup the device tree properly as the media graph has been created and the endpoints are linked properly.
The driver also appears to have been inserted successfully.
The problem I’m currently hitting is starting streaming on the that video device results in errors being thrown.
I’ve been using this site as a guide to enable more logging. the repeated error I’m seeing in the trace file is:
kworker/0:2-141 [000] ....... 2962.498878: rtcpu_nvcsi_intr: tstamp:93236202390 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:2-141 [000] ....... 2962.498879: rtcpu_nvcsi_intr: tstamp:93236202390 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000008
kworker/0:2-141 [000] ....... 2962.498879: rtcpu_nvcsi_intr: tstamp:93236203039 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x0000000a
kworker/0:2-141 [000] ....... 2962.498880: rtcpu_nvcsi_intr: tstamp:93236203039 class:CORRECTABLE_ERR type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x0000000a
kworker/0:2-141 [000] ....... 2962.498881: rtcpu_nvcsi_intr: tstamp:93236203661 class:GLOBAL type:STREAM_NOVC phy:0 cil:0 st:0 vc:0 status:0x00000001
kworker/0:2-141 [000] ....... 2962.498881: rtcpu_nvcsi_intr: tstamp:93236203661 class:GLOBAL type:STREAM_VC phy:0 cil:0 st:0 vc:0 status:0x00000002
Any ideas how to debug this further? I’ve looked through the TRM and CORRECTABLE_ERR seems to point to a CRC error potentially.
/sys/kernel/debug/tracing/trace attached
full-trace.txt (1.2 MB)
