There are 4 ethernet ports available but out of 1 is actively detected in the system.
lspci shows 4 ports but 3 are unprogrammed.
root@localhost:~# lspci | grep -i ethernet
0007:03:00.0 Ethernet controller: Intel Corporation I210 Gigabit Unprogrammed (rev 03)
0007:04:00.0 Ethernet controller: Intel Corporation I210 Gigabit Unprogrammed (rev 03)
0007:05:00.0 Ethernet controller: Intel Corporation I210 Gigabit Unprogrammed (rev 03)
0008:01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
root@localhost:~#
ifconfig shows only 1 ethernet port is active.
root@localhost:~# ifconfig
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:f2:f0:0d:16 txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enP8p1s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 134.XXXXX netmask 255.255.255.0 broadcast 134.86.62.255
inet6 fe80::cfba:b43:a76c:e4f4 prefixlen 64 scopeid 0x20<link>
ether 48:XXXXXX txqueuelen 1000 (Ethernet)
RX packets 42365 bytes 3045144 (2.9 MiB)
TX packets 3709 bytes 474560 (463.4 KiB)
device interrupt 68 base 0x5000
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
rndis0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 92:XXXXX txqueuelen 1000 (Ethernet)
usb0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 36:XXXXXX txqueuelen 1000 (Ethernet)
root@localhost:~#
Anybody face a problem like this ? Is it something related to the firmware update ? kindly help on this issue. Thank you.
