001
I’m building code with Jetson TK1 and ZED Camera.
I’m using OpenCV for vision based object tracking.
in windows, I can find OpenCV library files in programfiles\zed\dependencies folder.
but now I feel confused about where I can found library files.
I found it on usr/include/opencv2/
is it correct?
(it is not important question though…)
002
it is important question…
when I compile code in windows it work very well
I can use
‘connectedComponentsWithStats’ Function and
‘CAP_PROP_FRAME_HEIGHT’
‘CAP_PROP_FPS’
‘CAP_PROP_WIDTH’
‘CC_STAT_AREA’
‘CC_STAT_HEIGHT’
in imgproc.hpp
but I can’t use this functions and variables in Jetson TK1
when I compile same code with window I met this error :
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp: In function ‘int main()’:
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:55:13: error: ‘CAP_PROP_FRAME_WIDTH’ was not declared in this scope
cap.set(CAP_PROP_FRAME_WIDTH,320);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:56:13: error: ‘CAP_PROP_FRAME_HEIGHT’ was not declared in this scope
cap.set(CAP_PROP_FRAME_HEIGHT,240);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:104:27: error: ‘CAP_PROP_FPS’ was not declared in this scope
int fps = cap.get(CAP_PROP_FPS);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:146:79: error: ‘connectedComponentsWithStats’ was not declared in this scope
stats, centroids, 8,CV_32S);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:152:45: error: ‘CC_STAT_AREA’ was not declared in this scope
int area = stats.at(j, CC_STAT_AREA);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:161:43: error: ‘CC_STAT_LEFT’ was not declared in this scope
int left = stats.at(idx, CC_STAT_LEFT);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:162:43: error: ‘CC_STAT_TOP’ was not declared in this scope
int top = stats.at(idx, CC_STAT_TOP);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:163:44: error: ‘CC_STAT_WIDTH’ was not declared in this scope
int width = stats.at(idx, CC_STAT_WIDTH);
/home/ubuntu/WebcamLabelingOpenCV/src/main.cpp:164:46: error: ‘CC_STAT_HEIGHT’ was not declared in this scope
int height = stats.at(idx, CC_STAT_HEIGHT);
make[2]: *** [CMakeFiles/ZED_with_OpenCV.dir/src/main.o] Error 1
make[1]: *** [CMakeFiles/ZED_with_OpenCV.dir/all] Error 2
make: *** [all] Error 2
How Can I solve this problem?
I searched usr/include/opencv2/imgproc/imgproc.hpp and there were no such a variables and functions…
