libatomic.so.1 => /usr/lib/aarch64-linux-gnu/libatomic.so.1 (0x0000007f88bd1000)
libnvbuf_utils.so.1.0.0 => not found
libnppig.so.10 => /usr/local/cuda-10.2/targets/aarch64-linux/lib/libnppig.so.10 (0x0000007f8704e000)
libcuda.so.1 => not found
Running on Jetson AGX. The process runs on the host with no issues.
Running docker with flags --runtime nvidia --privileged returns with error:
Which JetPack version do you use?
You will need a JetPack 4.6 environment for the container.
We can launch it and run a vectorAdd sample without issue.
Please give it a try.
$ sudo docker run -it --rm --net=host --runtime nvidia -e DISPLAY=$DISPLAY -v /usr/local/cuda-10.2/samples/:/usr/local/cuda-10.2/samples -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/l4t-cuda:10.2.460-runtime
[Vector addition of 50000 elements]
Copy input data from the host memory to the CUDA device
CUDA kernel launch with 196 blocks of 256 threads
Copy output data from the CUDA device to the host memory
Test PASSED
Done
