Missing omniverse documentation
I have noticed that many functions just do not have documentation available online and I am wondering if omniverse is free or do I need to get enterprise version to get access to documentation?
For example, if you were to look at the methods that some function has lets say the viewport.
vp_window_active = get_active_viewport_window()
viewport_api = vp_window_active.viewport_api
print(f"Attributes and methods of viewport_api: {dir(viewport_api)}")
This is what the output will be:
[py stdout]: Attributes and methods of viewport_api: ['_ViewportAPI__ViewportSubscription',
'_ViewportAPI__accelerate_rtx_changed', '_ViewportAPI__accelerate_rtx_picking',
'_ViewportAPI__accelerate_rtx_picking_sub', '_ViewportAPI__aspect_ratios', '_ViewportAPI__callback_args',
'_ViewportAPI__clean_weak_views', '_ViewportAPI__create_scene_camera_model', '_ViewportAPI__fill_frame',
'_ViewportAPI__first_synch', '_ViewportAPI__flat_rendered_projection', '_ViewportAPI__flatten_matrix',
'_ViewportAPI__frame_changed', '_ViewportAPI__freeze_frame', '_ViewportAPI__get_conform_policy',
'_ViewportAPI__hydra_texture', '_ViewportAPI__is_requires_scene_camera_model',
'_ViewportAPI__lock_to_render_result', '_ViewportAPI__ndc_to_world', '_ViewportAPI__notify_objects',
'_ViewportAPI__notify_scene_views', '_ViewportAPI__projection', '_ViewportAPI__render_settings_changed',
'_ViewportAPI__requires_scene_camera_model', '_ViewportAPI__scene_camera_model',
'_ViewportAPI__scene_camera_model_import_failed', '_ViewportAPI__scene_views',
'_ViewportAPI__set_hydra_texture', '_ViewportAPI__subscribe_to_change', '_ViewportAPI__time',
'_ViewportAPI__transform', '_ViewportAPI__updates_enabled', '_ViewportAPI__usd_context_name',
'_ViewportAPI__view', '_ViewportAPI__view_changed', '_ViewportAPI__viewport_changed',
'_ViewportAPI__viewport_id', '_ViewportAPI__viewport_texture', '_ViewportAPI__world_to_ndc', '__class__',
'__del__', '__delattr__', '__dict__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__',
'__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__module__', '__ne__', '__new__', '__reduce__',
'__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', '__weakref__',
'_conform_projection', '_hydra_texture', '_notify_frame_change', '_notify_render_settings_change',
'_scene_camera_model', '_settings_path', '_sync_viewport_api', '_viewport_texture', 'add_scene_view',
'camera_path', 'display_render_var', 'fill_frame', 'fps', 'frame_info', 'freeze_frame', 'full_resolution',
'get_active_camera', 'get_full_texture_resolution', 'get_render_product_path', 'get_texture_resolution',
'get_texture_resolution_scale', 'hydra_engine', 'id', 'lock_to_render_result', 'map_ndc_to_texture',
'map_ndc_to_texture_pixel', 'ndc_to_world', 'pick', 'projection', 'query', 'remove_scene_view', 'render_mode',
'render_product_path', 'request_pick', 'request_query', 'resolution', 'resolution_scale', 'schedule_capture',
'set_active_camera', 'set_hd_engine', 'set_render_product_path', 'set_texture_resolution',
'set_texture_resolution_scale', 'set_updates_enabled', 'stage', 'subscribe_to_frame_change',
'subscribe_to_render_settings_change', 'subscribe_to_view_change', 'time', 'transform', 'updates_enabled',
'usd_context', 'usd_context_name', 'view', 'viewport_changed', 'wait_for_render_settings_change',
'wait_for_rendered_frames', 'world_to_ndc']
Now I want to get documenation about:
viewport_api.pick()
viewport_api.request_pick()
They are present in the list of methods above but I cannot find them online. Is this documentation missing, or is it not available to public or something on those lines? I have noticed this with a few other scenarios as well hence the question.
I know its a weird question but would love to know whats happening.
Thanks a lot,
Siddharth
Hi there, and thanks for your question. Yes, I understand that we do have some way to go, to create documentation for all the many aspects of Omniverse and the extensions. Have you searched through our main Omniverse Docs page for anything that may help ? NVIDIA Omniverse Documentation
