mlx4_core : Missing UAR, aborting
OS: Ubuntu 16.04.3 LTS
$ lspci | grep Mellanox
01:00.0 Ethernet controller: Mellanox Technologies MT27520 Family [ConnectX-3 Pro]
$ mstflint -d 01:00.0 q
Image type: FS2FW Version: 2.42.5000FW Release Date: 5.9.2017Product Version: 02.42.50.00Rom Info: type=PXE version=3.4.752 devid=4103Device ID: 4103PSID: MT_2340111023
I have installed all drivers, ran ‘/etc/init.d/mlnx-en.d retstart’ , got :
Unloading NIC driver: [ OK ]
Loading NIC driver: [ OK ]
BUT can’t see mellanox interface (ifconfig -a)
when I type now ‘dmesg | grep mlx’ , I get:
[0.991278] mlx_compat: loading out-of-tree module taints kernel.[0.991286] mlx_compat: module verification failed: signature and/or required key missing - tainting kernel[0.992456] mlx4_core: Mellanox ConnectX core driver v4.1-1.0.2 (27 Jun 2017)[0.992479] mlx4_core: Initializing 0000:01:00.0[0.992621] mlx4_core 0000:01:00.0: Missing UAR, aborting
What is the problem here?
P.S. I had no problem with this NIC on my computer, when used Ubuntu 14.04 LTS
Is this issue still actual to you?
I had the same issue on ConnectX-3 Pro, caused by large number of VFs I put into the HCA configuration file.
Symptoms (dmesg output):
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: [15b3:1007] type 00 class 0x028000
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: reg 0x10: [mem 0xf7900000-0xf79fffff 64bit]
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: reg 0x18: [mem 0xf4000000-0xf47fffff 64bit pref]
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: reg 0x30: [mem 0xf7800000-0xf78fffff pref]
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: reg 0x134: [mem 0x00000000-0x007fffff 64bit pref]
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: VF(n) BAR2 space: [mem 0x00000000-0x03ffffff 64bit pref] (contains BAR2 for 8 VFs)
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: BAR 2: no space for [mem size 0x00800000 64bit pref]
Mar 31 17:36:17 macpro kernel: pci 0000:06:00.0: BAR 2: failed to assign [mem size 0x00800000 64bit pref]
Mar 31 21:09:48 macpro kernel: mlx4_core: Mellanox ConnectX core driver v4.3-1.0.1
Mar 31 21:09:48 macpro kernel: mlx4_core: Initializing 0000:06:00.0
Mar 31 21:09:48 macpro kernel: mlx4_core 0000:06:00.0: enabling device (0100 → 0102)
Mar 31 21:09:48 macpro kernel: mlx4_core 0000:06:00.0: Missing UAR, aborting
Solution:
  1. Collect FW-related information about your HCA, you need to know PSID
# mstflint -d 06:00.0 q full
Image type: FS2
FW Version: 2.42.8016
FW Release Date: 21.3.2018
MIC Version: 2.0.0
Config Sectors: 2
PRS Name: cx3pro_MCX354A_fdr_09v.prs
Device ID: 4103
PSID: MT_1090111019
  1. Download FW for your particular HCA and unpack it.
  • In my case it is ConnectX3Pro-rel-2_42_6000-web.tgz
  • the archive contains set of *.ini files for different HCAs based on the same chip.
  • find the configuration file for your PSID:
# grep MT_1090111019 *.ini
MCX354A-FCC_Ax.ini:PSID = MT_1090111019
  1. Dump HCA configuration file, compare it to the original configuration file:
# mstflint -d 06:00.0 dc current.ini
# diff -u MCX354A-FCC_Ax.ini current.ini
  1. Next, add a few parameters into the [HCA] section to disable sr_iov and reduce the number of VFs to 4 (safe value in my case):
[HCA]
hca_header_subsystem_id = 0x0003
hca_header_device_id = 0x1007
dpdp_en = true
eth_xfi_en = true
mdio_en_port1 = 0
num_pfs = 1
total_vfs = 4
sriov_en = false
  1. Create the new firmware image, which includes the new configuration file
*# mlxburn -fw ./fw-ConnectX3Pro-rel.mlx -c current-sriov.ini *
-wrimage ./fw-ConnectX3Pro-rel-2_42_8016-MCX354A-FCC_Ax-FlexBoot-3.4.752.bin
  1. Burn it
mlxfwmanager -d /dev/mst/mt4103_pciconf0 -i fw-ConnectX3Pro-rel-2_42_8016-MCX354A-FCC_Ax-FlexBoot-3.4.752.bin -u
  1. Reboot and check that mlx4_core driver loads now for your HCA.
The issue is related to PCI allocation in Ubuntu 16.04.3 (Ubuntu kernel cannot allocate enough memory to bring up network interfaces during boot)
Please add the following line to grub2 :
  • edit /etc/default/grub
  • add GRUB_CMDLINE_LINUX_DEFAULT=" pci=realloc=off"
  • update-grub
  • Reboot
Thanks,
Samer
This didn’t work for me, but enabling SR-IOV in the motherboard BIOS did in case anyone stumbles across this same issue. Under chipset features on an AMD motherboard.
