Mlx5 udp out-of-order between fragmented and non-fragmented UDP packets when sender is using mlx4
Hi:
I am a user of mellanox ethernet card and have two type cards ConnectX-4 LX and ConnectX-3 Pro. And they all running on Redhat Linux.
I get a problem of udp reordering between fragmented and non-fragmented UDP packets. when the packages larger than MTU mixed with packages smaller than MTU, ConnectX-4 LX using mlx5 on receive side’s udp flow will seperate into 2 flows. So I use the below command to solve it.
ethtool -N ethx rx-flow-hash udp4 sd
the command change 4-tuple hash for UDP to 2-tuple and work perfect .Udp traffic between 2 ConnectX-4 LX is ordered no matter fragment or not.
BUT when I use the ConnectX-3 Pro use mlx4 as sender side, the ConnectX-4 LX using mlx5 as receiver become out-of-order. It seem that the command “ethtool -N ethx rx-flow-hash udp4 sd” has no effort for the udp packages sended by mlx4.
Now I got below situation for udp traffic :
CX4 —> CX4 good
CX4 —> other brand card good
other brand card → CX4 good
CX3 —> other brand card good
CX3 —> CX4 OUT-OF-ORDER!
I think the sender side should be no problem, because other brand card can get right package order. Maybe in the module mlx5 some special function is ​on effort when sender is a mlx4?
​ So maybe someone can help me. very very think you.
I use the attach c program to test out-of-order:
Usage:
Compile on Linux:
gcc udp_server_seq.c -o udp_server_seq
gcc udp_client_seq.c -o udp_client_seq
Run:
server side:
./udp_server_seq | tee a.txt
client side:
./udp_client_seq serverip 8000
Check:
./ooo2.py a.txt or open a.txt
and the out-of-order ratio is 20% of my test.
udp_server_seq.c (1.74 KB)
udp_client_seq.c (2.38 KB)
ooo2.py (584 Bytes)
