I’m working on a Linux Cluster (DualCore Opteronen) with MPI-CH1.2.7 and PGI6.1.
When I try to compile MM5-MPP I get the following error message:
/home/trachte/software/mpich/bin/mpicc -c -I/home/trachte/software/mpich/include
-I…/…/MPP -I…/…/MPP/RSL -I…/…/pick -I…/…/MPP/debug -I…/…/MPP/RSL/RSL -DMPP1 -DIOR=2 -DIWORDSIZE=4 -DRWORDSIZE=4 -DLWORDSIZE=4 -DASSUME_HOMOGENEOUS_E NVIRONMENT=1 -DMPI -I/home/trachte/software/mpich/include milliclock.c
/home/trachte/software/mpich/bin/mpif90 -o mm5.mpp addall.o addrx1c.o addrx1n.o bdyin.o bdyrst.o bdyten.o bdyval.o cadjmx.o coef_diffu.o condload.o consat.o con vad.o couple.o date.o dcpl3d.o dcpl3dwnd.o decouple.o define_comms.o diffu.o dif fth.o diffthd.o diffmoi.o diffintp.o dm_io.o dots.o dtfrz.o fillcrs.o fkill_mode l.o gamma.o gauss.o hadv.o init.o initsav.o initts.o kfbmdata.o kill_model.o lb_ alg.o lbdyin.o mhz.o mm5.o mp_equate.o mp_initdomain.o mp_shemi.o mparrcopy.o mp aspect.o nconvp.o nudge.o output.o outsav.o outtap.o outts.o outts_c.o param.o p aramr.o rdinit.o rho_mlt.o savread.o settbl.o setvegfr.o sfcrad.o shutdo.o slab. o solar1.o solve.o sound.o subch.o trans.o transm.o upshot_mm5.o vadv.o vadv2.o vecgath.o write_big_header.o write_fieldrec.o write_flag.o exmoiss.o cup.o cupara3.o maximi.o minimi.o mrfpbl.o tridi2.o init nest.o chknst.o nstlev1.o nstlev2.o nstlev3.o nstlev4.o nstlev5.o mp_stotndt.o smt2.o bcast_size.o merge_size.o mp_feedbk.o rdter.o lwrad.o swrad.o milliclock.o ./…/MPP/RSL/RSL/librsl.a -DDEC_ALPHA -O2 -Mcray=pointer -tp p6 -Mnoframe -byteswapio -L/home/trachte/software/mpich/lib -lfmpich -lmpich
/usr/bin/ld: /crtbegin.o: No such file: No such file or directory
make[1]: [all] Error 2 (ignored)
/bin/mv mm5.mpp …/…/Run/mm5.mpp
/bin/mv: cannot stat mm5.mpp': No such file or directory make[1]: [all] Error 1 (ignored) make[1]: Leaving directory
/home/trachte/MM5/MPP/build’
I hope someone can help me to fix my problem
Thanks a lot!
Best Regards
Katja
