Modify AI-NVR to use a custom deepstream python script
• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) 6.2
• TensorRT Version 10.7.0.23
• Issue Type( questions, new requirements, bugs) question
Hi, i have a custom deepstream python pipeline script to do face detection and some processing later using probes. I want to run this script with VST and SDR and redis the microservices that are in AI NVR application do you have a sample or documentation that can help in this task? Would be really Helpful Thanks.
Move to JPS forum.
I suggest you integrate your model for face detection into currently DeepStream microservice in AI-NVR: AI NVR — Jetson Platform Services documentation
I see for the python version in deepstream sample app 5 they are using pyservicemaker library. is there a python version with just deepstream and Gstreamer since it mentions in the pyservicemaker documentation that it is in alpha stage .
We recommend using pyservicemaker instead of pyds.
