Link Deepstream app to SDR
Hello all,
I have built a custom deepstream pipeline to do realtime object detection with region crossing alerts. Currently the pipeline has a dynamic batch setting turned on which allows multiple (2-4) streams to work simultaneously on the pipeline. Due to some fluctuations in the network there are situations where the rtsp stream might get disconnected. During this time my deepstream pipeline’s NvStreammux sends an EOS to that particualar stream. How do i recover from this without restarting the other stream which is running?
On a secondary note i came across VST + SDR which solves this exact problem for me but i couldn’t find anything to support the integration of them with my custom pipeline. Do you have any documentation for this or steps on how to execute this quickly?
Thank you
Subham
• Hardware Platform (Jetson / GPU) - Jetson Xavier NX
• DeepStream Version - 6.3
• JetPack Version (valid for Jetson only) - 5.1
• TensorRT Version - 8.5.2.2
• Issue Type( questions, new requirements, bugs) - questions
Are you working with AI NVR from JPS here: DeepStream Perception — Metropolis on Jetson documentation 0.1.0 documentation?
Yes, but i have a custom application and nothing related to AI NVR. I am trying to solve the problem mentioned in this url
with VST + SDR (if possible on Jetson Xavier NX)
AI NVR in JPS will use VST + SDR + DeepStream. Does this resolve your problem? Are you still have issue need to address in this topic?
Thank you for the reply @kesong
I am not looking to deploy AI NVR rather have my own pipeline in deepstream where i need to run this. Can you point me to a documentation where i can use my pipeline with VST & SDR?
Also, please let me know if these tools will work on Jetson Xavier NX with Jetpack 5.1.3?
VST and SDR are provided in JPS on Jetpack 6.0. You need upgrade to Jetpack 6.0 to use those microservices.
Is the Jetpack 6.0 supported on Jetson Xavier NX?
Sorry, Jetson Xavier NX can’t use Jetpack 6.0. Need Jetson Orin to use Jetpack 6.0.
