Because we don’t have enough GPIO for use, we went to use the four pins of I2S0(We don’t need to use this specific function).
I find the pin mapping in this file “Jetson_TX1_Generic_Customer_Pinmux_Customer_Release.xlsm” and the four pins were mapping to GPIO_PB00 ~ GPIO_PB03, now I have two question as below:
1.I could find the TK1 GPIO definition in arch/arm/mach-tegra/gpio-names.h, but where is the TX1?
I try to control the I2S0_SDIN(GPIO3_PB01) as GPIO9 which TK1 defined, but this pin couldn’t output what I expect.
2.Continuous the first question, should I modify the setting for I2S0 which may be set in bootloader or device tree.
You can check the pimux table. You can see the SFIO0, SFIO1, SFIO2, SFIO3 and for the GP01 ball name DAP1_DIN config as GPIO you need to config this pin to first empty field.
