Hi:
I installed Nvidia Modulus v22.03 successfully on my laptop. However, when I was trying to install Nvidia Modulus v22.03 on a cluster with a Conda environment (no root). After installation, the job helmholtz.py cannot run with the following error, I wish to ask how to solve this:
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/site-packages/modulus-22.3-py3.9.egg/modulus/distributed/manager.py”, line 124, in initialize
DistributedManager.initialize_env()
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/site-packages/modulus-22.3-py3.9.egg/modulus/distributed/manager.py”, line 67, in initialize_env
rank = int(os.environ.get(“RANK”))
TypeError: int() argument must be a string, a bytes-like object or a number, not ‘NoneType’
During handling of the above exception, another exception occurred:
File “/project/user/DL/modulus2203/examples/helmholtz/helmholtz.py”, line 95, in
run()
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/site-packages/modulus-22.3-py3.9.egg/modulus/hydra/utils.py”, line 58, in func_decorated
DistributedManager.initialize()
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/site-packages/modulus-22.3-py3.9.egg/modulus/distributed/manager.py”, line 127, in initialize
DistributedManager.initialize_slurm(port)
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/site-packages/modulus-22.3-py3.9.egg/modulus/distributed/manager.py”, line 108, in initialize_slurm
DistributedManager.setup(
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/site-packages/modulus-22.3-py3.9.egg/modulus/distributed/manager.py”, line 150, in setup
os.environ[“MASTER_ADDR”] = addr
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/os.py”, line 684, in setitem
value = self.encodevalue(value)
File “/project/user/DL/anaconda3/envs/modulus2203/lib/python3.9/os.py”, line 756, in encode
raise TypeError(“str expected, not %s” % type(value). name )
TypeError: str expected, not NoneType
