I’ve noticed nvidia-smi is not included with the NVIDIA driver on my TK1. Is there any way to monitor GPU utilization by writing a CUDA application? I’ve perused the APIs, but haven’t found any mechanism to get this information.
Without the NVML library or the NV-CONTROL X extension used by the nvidia-settings app, there is no other way that I know of to get that information. I would suggest to request that the NVML library (and thus nvidia-smi) be made available on Jetson if this is what you want.
I’m able to use the stock linux sensors utility from the lm-sensors package to see a bunch of different temperature sensors. It won’t get you memory utilization, but you will be able to see the temperature and make sure you’re not overheating:
$ sensors
CPU-therm-virtual-0
Adapter: Virtual device
temp1: +35.5°C (crit = +101.0°C)
GPU-therm-virtual-0
temp1: +32.5°C (crit = +101.0°C)
MEM-therm-virtual-0
temp1: +31.5°C (crit = +101.0°C)
PLL-therm-virtual-0
temp1: +33.5°C
Tboard_tegra-virtual-0
temp1: +25.0°C
Tdiode_tegra-virtual-0
temp1: +29.0°C
The sensors tool is built on top of a standard Linux API called libsensors, and there are a number of graphical front-ends for it as well.
I’m seeing similar temps on my TK1. Running a GPU task continuously drove the temps up by a few degrees.
The rather robust fan seems to be effective. :)
FYI, I installed lm-sensors by downloading and building the package as well as installing flex and bison.
Thank everyone, lm-sensors seems to be the best option for now. Under full load I have yet to see the GPU get above 39°C. At idle, it’s around 29°C.
I installed lm-sensors through the package manager; much easier than trying to compile it from souce:
sudo apt-get install lm-sensors
@namniart, interesting! I first tried to install lm-sensors with apt-get but the package wasn’t available.
Sigh, I must have something wrong with my apt-get configuration.
Did you uncomment the universe repository in /etc/apt/sources.list?
apt-get fails to get lm-sensors when I try, and I get similar errors on other packages, I wonder if some step of the Jetson setup messed up the package system?:
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package lm-sensors is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘lm-sensors’ has no installation candidate
Strange, it installed for me without problems, and I haven’t altered my repos. What version of Linux for Tegra do you have? I have Rel 19.
I have the same result as @tachyon_john.
Yeah; I enabled the universe repos. It’s usually one of the first things I do when I set up a new Ubuntu machine, and a bunch of the other stuff I’m doing requires packages from universe.
Yes, it would appear that many of the “missing” packages are in the universe repo, I found a few of the ones I was looking for there.
