Greetings all.
I am using a desktop with 3 monitors.
2 x 21-inch Dell monitors
1 x 34-inch LG monitor
The 2 Dell monitors, one is connected to the VGA port on-board, and the second one is connected to the onboard HDMI port.
The third and the large monitor 34 inches LG is connected to the HDMI port of NVIDIA GeForce GTX 1650 SUPER.
The system was using Windows 10, but I replaced it with Fedora 32 KDE last week, also installed Nvidia driver and CUDA successfully then. It has been working well until today, but I have no idea what really happened in the system or if some system update has undergone without my knowledge, when I tried to boot up the machine today morning, all I can see only the large 32inch LG monitor connected to Nvidia graphic card is showing up. The system is showing disconnected status for the rest two Dell monitors connected on-board VGA and HDMI ports which are using Intel onboard integrated GPU.
Have you guys faced the same issue?.
^ john @ fedora ~ > $ lspci | grep VGA
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 510 (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation TU116 [GeForce GTX 1650 SUPER] (rev a1)
^ john @ fedora ~ > $ sudo xrandr
Screen 0: minimum 8 x 8, current 2560 x 1080, maximum 32767 x 32767
DVI-D-0 disconnected (normal left inverted right x axis y axis)
HDMI-0 connected primary 2560x1080+0+0 (normal left inverted right x axis y axis) 798mm x 334mm
2560x1080 59.98*+ 74.99 50.00
1920x1080 75.00 60.00 59.94 50.00
1680x1050 59.95
1600x900 60.00
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94 50.00
1152x864 60.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x576 50.00
720x480 59.94
640x480 75.00 59.93 59.94
DP-0 disconnected (normal left inverted right x axis y axis)
DP-1 disconnected (normal left inverted right x axis y axis)
^ john @ fedora ~ > $ sudo lsmod | grep 'i915\|nvidia\|nouveau'
i2c_nvidia_gpu 16384 0
nvidia_drm 57344 9
nvidia_modeset 1216512 24 nvidia_drm
nvidia 27701248 1286 nvidia_modeset
i915 2621440 1
i2c_algo_bit 16384 1 i915
drm_kms_helper 262144 2 nvidia_drm,i915
cec 61440 2 drm_kms_helper,i915
drm 626688 13 drm_kms_helper,nvidia_drm,i915
video 53248 2 asus_wmi,i915
^ john @ fedora ~ > $ sudo nvidia-smi
Mon Oct 12 18:14:56 2020
| NVIDIA-SMI 455.28 Driver Version: 455.28 CUDA Version: 11.1 |
| | | MIG M. |
| 0 GeForce GTX 165... Off | 00000000:01:00.0 On | N/A |
| 0% 49C P8 12W / 100W | 465MiB / 3911MiB | 4% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1366 G /usr/libexec/Xorg 183MiB |
| 0 N/A N/A 1563 G /usr/bin/kwin_x11 86MiB |
| 0 N/A N/A 1566 G /usr/bin/plasmashell 64MiB |
| 0 N/A N/A 1842 G ...akonadi_archivemail_agent 2MiB |
| 0 N/A N/A 1853 G .../akonadi_mailfilter_agent 2MiB |
| 0 N/A N/A 1860 G ...n/akonadi_sendlater_agent 2MiB |
| 0 N/A N/A 1862 G ...nadi_unifiedmailbox_agent 2MiB |
| 0 N/A N/A 2060 G ...AAAAAAAAA= --shared-files 113MiB |
^ john @ fedora ~ > $ echo $XDG_SESSION_TYPE
x11
^ john @ fedora ~ > $ sudo grep GRUB_CMDLINE_LINUX /etc/sysconfig/grub
GRUB_CMDLINE_LINUX="resume=/dev/mapper/fedora_fedora-swap rd.lvm.lv=fedora_fedora/root rd.lvm.lv=fedora_fedora/swap rhgb quiet rd.driver.blacklist=nouveau modprobe.blacklist=nouveau nvidia-drm.modeset=1"
^ john @ fedora ~ > $ cat /etc/modprobe.d/blacklist.conf
blacklist nouveau
options nouveau modeset=0
options nvidia-drm modeset=1
^ john @ fedora ~ > $ cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 455.28
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
nvidia-bug-report Dropbox - nvidia-bug-report.log.gz - Simplify your life
nvidia-settings Imgur: The magic of the Internet
What could be wrong here?.
