Anyone has solve this issue?
I tried everything. but with no luch.
nvidia-bug-report.log.gz (1.33 MB)
Please run nvidia-bug-report.sh as root and attach the resulting .gz file to your post. Hovering the mouse over an existing post of yours will reveal a paperclip icon.
https://devtalk.nvidia.com/default/topic/1043347/announcements/attaching-files-to-forum-topics-posts/
thank you generix, I did it
You installed different drivers over one another so it’s broken now. Please re-run the .run installer you used with --uninstall option, the uninstall al nvidia packages using
sudo apt remove “nvidia*”
in an empty directory. Then reinstall the driver using the Software&updates application.
If this doesn’t resolve the issue, please create a new nvidia-bug-report.log.
sudo apt remove nvidia* command return…
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package nvidia-bug-report.log
E: Couldn't find any package by glob 'nvidia-bug-report.log'
E: Couldn't find any package by regex 'nvidia-bug-report.log'
E: Unable to locate package nvidia-bug-report.log.gz
E: Couldn't find any package by glob 'nvidia-bug-report.log.gz'
E: Couldn't find any package by regex 'nvidia-bug-report.log.gz'
Now I see thre monitor but one is disabled and i cannot enable it
nvidia-bug-report.log.gz (1.65 MB)
Please change to an empty directory and re-run
thank you I moved in a clear directory
I use Software&Update as you sudgested: I installed nvidia-435 propetary driver
at first all 3 monitors show up ( but the hdmi monitor still black with no signal)
I rebootes and now only hdmi screen is turn on
I attached to the prev message my report log thanks
Please delete /etc/X11/xorg.conf
It worked!!! Thank you generix!!
Hi, does Ubuntu can solve with same method?
