Monster Hunter wilds Vertex Explosions and performance issues
i was hoping it would been fixes ages ago due to the first beta being broken but no one reported it as always! trying to change that don’t worry.
here are the many images at the start of the game NOW IT doesn’t always happen but still is an issue.
Another issue on linux with nvidia is that one boot of the game runs amazing! 120fps locked 1440p maxed and the second boot runs like garbage 47fps same settings and it makes no sense and the power draw is much lower. Also pyroveil fails to work as well.
570.133.07
570.123.06
Distro’s tested:
Fedora 41/42/
Nobara 41
CachyOS
PikaOs 4
Thanks for the report. Progress for this issue is being tracked in bug 5124110.
is there any update on this?
While not an official fix, this issue can be resolved by using the pyroveil layer created by HansKristian(creator/maintainer of vkd3d-proton):
just follow the steps listed in the repository, add the launch argument, and while not a listed step, I would also remove the files in the root of your game’s directory:
vkd3d-proton.cache
vkd3d-proton.cache.write
and let it rebuild itself before running with the pyroveil layer enabled.
That is not a fix and never was sadly.
just wanted to give a +1 on this issue as i can’t repeat it with my 7900 xtx on my desktop but with my new framework 16 i am having this issue, i am currently using the 590 driver as provided by the gentoo repos
system specs
c2@gentoo ~ $ fastfetch
         -/oyddmdhs+:.                 c2@gentoo
     -odNMMMMMMMMNNmhy+-`              ---------
   -yNMMMMMMMMMMMNNNmmdhy+-            OS: Gentoo Linux x86_64
 `omMMMMMMMMMMMMNmdmmmmddhhy/`         Host: Laptop 16 (AMD Ryzen AI 300 Series) (A9)
 omMMMMMMMMMMMNhhyyyohmdddhhhdo`       Kernel: Linux 6.18.3-p1-cachyos
.ydMMMMMMMMMMdhs++so/smdddhhhhdm+`     Uptime: 11 hours, 25 mins
 oyhdmNMMMMMMMNdyooydmddddhhhhyhNd.    Packages: 1494 (emerge), 24 (flatpak)
  :oyhhdNNMMMMMMMNNNmmdddhhhhhyymMh    Shell: bash 5.3.9
    .:+sydNMMMMMNNNmmmdddhhhhhhmMmy    Display (NE160QDM-NZ6): 2560x1600 @ 1.6x in 16", 165 Hz [Built-in]
       /mMMMMMMNNNmmmdddhhhhhmMNhs:    WM: Hyprland 0.51.1 (Wayland)
    `oNMMMMMMMNNNmmmddddhhdmMNhs+`     Theme: Adwaita [GTK3]
  `sNMMMMMMMMNNNmmmdddddmNMmhs/.       Icons: gnome [GTK3]
 /NMMMMMMMMNNNNmmmdddmNMNdso:`         Cursor: Adwaita
+MMMMMMMNNNNNmmmmdmNMNdso/-            Terminal: kitty 0.45.0
yMMNNNNNNNmmmmmNNMmhs+/-`              Terminal Font: LiberationMono (11pt)
/hMMNNNNNNNNMNdhs++/-`                 CPU: AMD Ryzen AI 9 HX 370 (24) @ 5.16 GHz
`/ohdmmddhys+++/:.`                    GPU 1: AMD Radeon 890M Graphics [Integrated]
  `-//////:--.                         GPU 2: NVIDIA GeForce RTX 5070 Max-Q / Mobile [Discrete]
                                       Memory: 13.15 GiB / 93.59 GiB (14%)
                                       Swap: 0 B / 16.00 GiB (0%)
                                       Disk (/): 1.45 TiB / 1.80 TiB (81%) - xfs
                                       Local IP (wlp192s0): 10.0.0.146/24
                                       Battery (FRANDBA): 100% [AC Connected]
                                       Locale: en_US.UTF-8
c2@gentoo ~ $
