Win32 binaries and source code are attached, see bottom of posting.
I have used a week off to implement a really cute fractal renderer. This is still work in progress. It displays the Mandelbrot set in an unusual way, often referenced as “Buddhabrots” or “Nebulabrots”. It plots the escape trajectories of all points not belonging to the Mandelbrot set (those that escape to infinity when iterated). So in essence it is a scattered write torture test for your graphics card.
I think that I may have written the fastest Buddhabrot renderer on the planet. Prove me wrong.
Due to the statistical nature of rendering the fractal, generating deeply zoomed images was a challenge. You’ll simply not have enough trajectories hitting pixels in the zoomed region. I use an algorithm called Metropolis-Hastings to speed up rendering deep zooms. Otherwise you’d literally wait forever for an image. When zoomed, you can expect rendering to occur about at the speed a Polaroid photo appears. Image quality gets better over time.
I’ve implemented a novel physics-inspired coloring method which is now the default. It creates most astonishing images, some ressembling an oil sheen on water ;)
EDIT: This coloring method was originally suggested by kram1032 on fractalforums.com This is currently the forum where you’ll find the most interesting novel ideas in fractal generation (see e.g. the Mandelbulb or Mandelbox).
To zoom, drag a rectangle with the left mouse button and then right click into it. Right click outside the selection to remove it. Press and hold Ctrl and/or Shift to modify the behavior of the selection rectangle. All other key commands are explained on the console window (DOS box).
Feel free to make screenshots of the window contents and attach them here. The program cannot yet save images, so you’ve got to use your favorite screenshot or window capture tool. You can do renders at Full HD, but the window needs to fit the screen so you can take screen captures. The window’s maximize button can be useful here.
Place the DLLs from the attached zip archives in the Release folder in case the program yells for DLLs (they should all be part of CUDA toolkit and SDK). The various .BAT files contain parameter sets for different coloring methods and can also be used to start the program. Feel free to edit them, in particular the default window size and coloring parameters.
Use of GTX 260 or better is recommended. It still runs admirably on my laptop’s Geforce 9600M graphics card
Source code builds with CUDA toolkit 2.3 (or later?) when you place the Buddhabrot folder in the SDK’s C/src directory. Compute capability 1.1 or better is required due to global atomics used in Analysiskernel. This kernel can be commented out and compile options set to use sm_10 if you have a 8800 GTX card.
Linux and Mac persons will have to create a makefile for this project, best to base it on e.g. the “Sobel” SDK sample’s makefile.
Click on the thumbnails to see some test renders, and try the program for yourself. It’s free, no strings attached.
Christian
!(upload://kM4FWwnfeHSX2GZKNtmbnAfCnZq.jpeg)
DLLs2.zip (125 KB)
[This file was removed because it was flagged as potentially malicious] (255 KB)
Buddhabrot_wavelength.zip (158 KB)
