Multi-Camera DeepStream Pipeline for Dynamic Pallet Ingress Counting with Heavy Occlusion
Hi team,
I am building an automated industrial counting pipeline processing two opposing 1080p RTSP camera streams covering a warehouse loading zone. The target classes are stacked yarn bundles (bag) and rectangular cartons (carton).
Challenges:
  • High occlusion: Structural columns block ~35% of the static resting zone.
  • Pallet geometry: Stacks contain transverse interlocking tiers where internal units are obscured when stationary.
  • Visually homogeneous cargo: White wrapped bundles create low contrast along seams.
Proposed Pipeline:
  • nvmultiurisrcbin (2 streams) $\rightarrow$ nvstreammux $\rightarrow$ nvinfer (YOLOv8-seg / YOLOv11-seg engine in FP16) $\rightarrow$ nvtracker (ByteTrack / NvDCF).
  • Counting during ingress motion (while being moved by a pallet jack across the clear bay floor) rather than relying exclusively on resting snapshots behind the column.
Questions:
  1. For handling low-contrast white-on-white package seams, does NvDCF tracker maintain target ID persistence reliably across partial pillar occlusions, or should trajectory association be handled externally via custom downstream probe metadata?
  2. In multi-camera setups with opposing views, what is the best practice within DeepStream/Metropolis for cross-camera re-identification (MTMC) when package features are visually identical and lack color distinction?
  3. Is dynamic motion tracking during ingress generally preferred over multi-view 3D volumetric aggregation for industrial loading bays?
The opposing dual-camera setup for a loading zone is something we’ve dealt with a lot, and heavy occlusion on stacked yarn bundles specifically is brutal because the depth variation makes standard IoU-based tracking fall apart fast. We’ve been working through very similar counting challenges in industrial settings and have some hard-won lessons around camera angle calibration and tracker config tuning for exactly this kind of ingress/egress scenario. Are you currently trying to fuse the counts from both cameras at the pipeline level, or handling that reconciliation downstream after each stream produces its own count?
The combination of opposing camera angles plus heavy occlusion on stacked yarn bundles is genuinely one of the harder counting setups to get right, because your tracker ends up fighting itself when the same pallet disappears behind another from one view but not the other. We have been working through very similar multi-view ingress counting challenges in industrial environments and the cross-camera ID reconciliation piece is usually where things fall apart in practice. Are you currently doing any homography-based ground plane fusion between the two streams, or are you counting independently per camera and trying to deduplicate after the fact?
The dual opposing camera setup for a loading zone is exactly where occlusion gets brutal, because you almost always hit a blind spot no matter how you angle them when pallets stack unevenly. I work on computer vision deployments in industrial environments and counting with heavy occlusion across multiple streams is something my team has wrestled with a lot. One thing that helped us was leaning on cross-camera re-identification to reconcile counts rather than trusting either stream independently. Are you trying to get a final ingress count per shift, or do you need near-realtime counts as each pallet crosses the threshold?
Some thoughts on your three questions. This is general practice, not something I tested on your exact setup.
  1. NvDCF and occlusion. NvDCF combines visual features with a motion model, and it can carry a target through a short occlusion with its shadow tracking (see maxShadowTrackingAge in the tracker config). With white-on-white bundles the visual features are weak, so most of the persistence will come from motion and position. If IDs still switch behind the column, a simple association based on trajectory (position, size, direction) in a downstream probe is reasonable, because the bundles move in a fairly straight line on a pallet jack.
  2. Cross-camera ReID. When the items look identical, appearance ReID has almost nothing to match on, so I would not rely on it here. Use geometry and time instead: calibrate both cameras to the same floor plane and match by where and when something crosses it. Better still, avoid needing cross-camera identity at all. Pick one counting line that is clean in one camera and count there, and use the other camera only as a second opinion for the same pallet.
  3. Motion counting vs 3D volume. For a loading bay, counting during movement through a clear line is usually more robust than rebuilding a stationary stack with hidden units. nvdsanalytics can do line crossing with direction, so you get in/out counts per class without extra code. Count per pallet moving through, and check the total against the known pallet pattern (for example the expected bundles per tier) to catch misses.
Two practical tips: run a manual audit of about 20 pallets first to measure the real error before tuning anything, and keep the line far enough from the column that the object is fully visible when it crosses.
