• Hardware Platform (Jetson / GPU): jetson
• DeepStream Version: 5.0 GA
• JetPack Version (valid for Jetson only) : 4.4 Developer kit
• TensorRT Version : 7.1.x
Hi guys,
I tested the deepstream python apps on jetson xavier nx, for tracker with NvDCF, when I used multi-stream RTSP, the counting of each stream is not independent, why? i.e suppose we have two stream, the counting of there is:
stream 1 : 0,2,5,9,10 …
stream 2 :1,3,4,6,7,8, …
that means the tracker is applied to two stream instead of individual counting. and this state is occurred in the NvDCF tracker. How I can solve the problem?
