hi, i want the two processes use tensorRT to load different models,but xavier does not support mps.
So is there any way to reduce the time consuming caused by process switching?
YES. Please create two CUDA context for each engine(model) and run it with multi-thread.
You can find a similar implementation in our trtexec app.
/usr/src/tensorrt/samples/common/sampleInference.cpp
Thanks for your reply.
hi,I try to use multi-threaded approach,I found the following phenomenon
A few times, the time-consuming will increase greatly,Mostly normal(vgg infere:6.9ms, resnet50 infere:2.9ms)
[resnet50][info][PreProcess][cost time] :0.092ms
[vgg16][info][PreProcess][cost time] :0.369ms
[vgg16][info][Infere][cost time] :8.073ms
[vgg16][info][Post][cost time] :1.049ms
[resnet50][info][Infere][cost time] :9.606ms
[resnet50][info][Post][cost time] :0.032ms
[vgg16][info][PreProcess][cost time] :0.093ms
[resnet50][info][PreProcess][cost time] :0.094ms
[vgg16][info][Infere][cost time] :8.319ms
[vgg16][info][Post][cost time] :1.166ms
[resnet50][info][Infere][cost time] :9.564ms
[vgg16][info][PreProcess][cost time] :0.09ms
[resnet50][info][PreProcess][cost time] :0.47ms
[vgg16][info][Infere][cost time] :8.127ms
[vgg16][info][Post][cost time] :1.32ms
[resnet50][info][Infere][cost time] :9.051ms
[resnet50][info][Post][cost time] :0.031ms
[resnet50][info][PreProcess][cost time] :0.503ms
[vgg16][info][Infere][cost time] :8.23ms
Here are two possible causes for your reference.
1.
The default clock mode is dynamic and will cause the unstable performance.
Please maximize the device performance first.
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2.
Would you mind to check if there is any non-release memory inside your app?
This can be verified with tegrastats directly.
$ sudo tegrastats
