htopcu
1
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 5.1
• JetPack Version (valid for Jetson only) 4.5.1
• TensorRT Version 7.1.3+cuda10.2
• Issue Type( questions, new requirements, bugs) Question
How can I integrate second csi cam to below example ?
deepstream_csi.py (15.9 KB)
Does the first CSI camera work with your code?
If so, you can add your second csi camera as the second source. There is sample of multiple sources input with deepstream-test3.
Please make sure you are familiar with gstreamer knowledge and coding skills, and be familiar with gst-python before you start with pyds.
htopcu
4
Yes first camera works.
This is how I use it.
source = Gst.ElementFactory.make("nvarguscamerasrc", "src-elem")
source.set_property('bufapi-version', True)
and adding to pipeline and linking below.
But I don’t really understand how to add second csi with same way.
And deepstream_test_3 is all other thing with creating source bin.
Source bin is another kind of source. Just replace the source bin with your “nvarguscamerasrc”.
https://gstreamer.freedesktop.org/
It will be very hard for you to understand the sample codes if you are not familiar with gstreamer, gobject and gst-python.
htopcu
6
Thanks. I will check tutorials.
system
Closed
8
