I’m building a custom python app and i need to use the two CSI camera modules as sources for the app, I’m not really sure why i’m missing or doing wrong but i get the error:
Can you try with gst-launch to get the right pipeline and then start to write the python script? Your pipeline is wrong. Do you know anything about your camera? What is the output format of your camera? Frame rate?
seems like the pipeline example is for a older version of deepstream i got this error:
No such element or plugin 'nvosd'
I know my camera works, i have tested with other pipelines like the following and it works:
root@frank:/edge-appliance# gst-launch-1.0 nvarguscamerasrc sensor-id=0 ! nvvidconv ! nvegltransform ! nveglglessink
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21.000000 fps Duration = 47619048 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28.000001 fps Duration = 35714284 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 10.625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Output window was closed
Additional debug info:
/dvs/git/dirty/git-master_linux/3rdparty/gst/gst-nveglglessink/ext/eglgles/gsteglglessink.c(913): gst_eglglessink_event_thread (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0
Execution ended after 0:00:03.731645252
Setting pipeline to READY ...
CONSUMER: Done Success
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Setting pipeline to NULL ...
Freeing pipeline ...
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
Thanks for your guide, but i write the python script for your pipeline.
Do you know what the problem is on my original question? how to run mutiple csi cameras in one single pipeline?
I follow that example as starting point to my code, the sample use uridecodebin as source, no nvarguscamerasrc, with my understanding of gstreamer and deepstream, i was able to change the code to use nvaruscamerasrc, but i don’t why i’m getting the following not linked error:
root@frank:/deepstream-examples# python multi-csi-source.py
Creating Element: nvstreammux
Creating Source for Camera 1
Creating Source Bin
Creating Element: nvarguscamerasrc
Creating Source for Camera 2
Creating Source Bin
Creating Element: nvmultistreamtiler
Creating Element: nvvideoconvert
Creating Element: nvegltransform
Creating Element: nveglglessink
Creating Element: queue
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
Using winsys: x11
Camera index = 0
Camera mode = 2
seconds to Run = 0
Camera index = 1
Camera mode = 2
seconds to Run = 0
Error: gst-stream-error-quark: Internal data stream error. (1): gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstBin:source-bin-0/GstNvArgusCameraSrc:camera-source:
streaming stopped, reason not-linked (-1)
I’m not sure what part i’m missing, so i was looking for help in the forum.
I don’t think you understand gstreamer.
Your source bin is wrong. Your camera support multiple resolutions and frame rates, if you don’t tell the camera which resolution and frame rate you want to use, how can it work?
Please refer to the pipeline which you can run successfully. Your source should be “nvarguscamerasrc + capsfilter” but not a single “nvarguscamerasrc”. I can’t find any capsfilter in your “def create_source_bin(camera)”.
You can also try the two cameras pipeline before you start to implement the multiple source script.
Gstreamer automatically uses one of the defaults capabilities if you don’t explicit set one. so that’s not the problem, if i add one it won’t solve the problem. like with your pipeline example, if you remove the capabilities after the nvarguscamerasrc it will still run.
